64 gto front coil springs
Any one know what coil springs will raise front end 1-2" above stock height ? Thank you
I must ask. Why do want to raise it that much?
Tempest455 |
Moog 5272 should do the trick. 2" over stock. I have a set going on my 65 but it will be a couple months or longer before I will have it back together.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
I like the look when it sits a little higher than stock.
what application is the moog 5272 for ? Thank you
Moog 5272 are cataloged for 65-67 Cutlass sedan, convertible, and wagons with A/C. Also 67 GTO convertible without A/C.
Spring I.D 3.625 Wire diameter .650 Load height 11.00" Load 2279 Spring rate 333 Approx. free height 17.823" |
