Old 09-03-2009, 01:59 PM
bruwster bruwster is offline
Default 70 T/A part numbers help
Looking for help in getting the correct 70 T/A RAIII pullies, P.S. pump, cooling fan, starter, alternator, part numbers.
Car is a non A/C car.
Old 09-03-2009, 05:48 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I believe your starter would be a 1108436.
The alternator depends on if the car has A/C and/or rear window defroster or other options. If it was a base 37-amp alt then likely a 1100902.
1970 codes
1100902 37 amp
1100903 55 amp
1100904 61 amp rarest one
This is a good resource for some items.
http://thefirstgensite.com/library/partscounter/2-i.pdf
And this site can be handy sometimes, too.
http://www.teufert.net/partbook/
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 09-03-2009, 07:45 PM
TA455HO's Avatar
Default Here's some more
These I get a little fuzzy on, so anyone else jump in and correct me.
Main crank pulley
480507 0.659 F/8 P.S. exc. A.C PULLEY (7'/~6'' dia.) (2 groove) 1 1970 1970 0-36
Fan pulley
480511 1.062 F/8 P.S. exc. A.C PULLEY (2 groove) (77/8'' dia.) 1 1970 1970 1-1
P.S pulley
480513 6.655 F/8 P.S PULLEY, pump 1 1970 1970 6-29
P.S pump
7808536 6.605 F/8 P.S PUMP 1 1970 1970 6-23
Cooling fan numbers vary depending on how many blades. Since it is non A.C. I'm guessing not 7 blade as they were mostly used for A.C. cars (or H.D.). If it is 5 blade
480033 1.064 All V/8 exc. 307 FAN (5 blades) (19'' dia.) (25/16'' pitch) 1 1969 1974 1-3
My guide is obviously newer, so some of these might be supercedes.
Hope it helps some.
And welcome aboard...
