Old 01-07-2025, 06:49 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Default Out of hibernation
https://youtu.be/IRg_FQc3g7w?feature=shared
Feels good to be able to just start. Hoping for a track day soon
The Following 5 Users Say Thank You to Scott Stoneburg For This Useful Post:
Old 01-07-2025, 10:24 PM
chuckies76ta's Avatar
Nice. We need details Car, year, Engine details.. Is this the engine you hurt awhile back?
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 01-08-2025, 12:43 AM
AG's Avatar
AG AG is offline
Sounds nice, what was the idle rpm?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 01-08-2025, 05:29 AM
Yes, it's the same engine I hurt last year.
535 cu.in.
Ohio Forged crank, Eagle I-Beam 6.7 rods,
Diamond 17cc dishes pistons ( pump gas)
Cam Motion SR cam. 276/284@.050 -
.455/.450 lobe lift .773/.765 valve lift
CV-1 heads. & CV-1 single plane manifold.
1050 Holley Dominator
Last year it tore up the rocker arms. I had T&D build me a shaft rockers arm set up.
Idle RPM is 1300-1400
Old 01-08-2025, 09:37 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Excellent..... Good to hear!
Go fast, see Elvis!
Old 01-08-2025, 11:13 AM
535 cu.in.
Ok, Yes now I remember. Thanks for posting update. Sounds Awesome. How do you like the T&D setup?
Old 01-08-2025, 11:20 AM
burd's Avatar
burd burd is offline
Wait, wrong thread. Lol
No shadow, early spring fellas
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
I’m now Unburdened by what has been
Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers.
Old 01-08-2025, 12:44 PM
Rockers are really nice, the stands come as individual stands, designed to be pinned to the head. I had straps welded to the stands once they were set to make them solid together.
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 01-08-2025, 03:39 PM
Thanks Scott. Our cars are similar. I was curious on your rear gear and tire size and how fast you have been in the quarter mile. Also weight of car. There is a few guys on here with 67 and 68 running IA2 blocks.
Old 01-08-2025, 04:07 PM
Rear gear is 3.70s and 275/60-15 Drag radials. The fastest it's been in the 1/4 is 10.20 @ 131. That was with my 474 and Edelbrock heads. I can't remember the 1/8 time on that run. I run it at an 1/8 track more frequently due to the proximity of the track. It would run mid 6.40s at 106 -107. The only runs with the new 535 have been all leaving soft due to traction limits. But it's been 6.22@ 111 in the 1/8mi. So far. Hoping to have the traction sorted out.
Car weighed 3550 with the stock block 474.
Old 01-08-2025, 04:17 PM
Thanks Scott: So, at 6.22 your well in the 9's. Be interesting to see what actual 1/4 mile would be. Here is out latest time slip from last summer. Car weighs in at around 3620. I install a Hoosier 29x12x15 slick. Finally got it to hookup. I also went to global west control arms with adjustable shocks. I'd still like to try the 3.90 and go back to the 28" slick. F068. Can never get those pics upright. lol
Old 01-08-2025, 06:05 PM
I have Moroso Springs up front with Comp Engineering 3 way adjustable shocks, rear I have Cal trac split mono springs with Cal trac single adjustable shocks. I just need to play with the settings to see if I can make it hook. I did make a mount to set up my GoPro to watch the suspension work.
Old 01-11-2025, 10:41 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Are you close to Bradenton?
Old 01-12-2025, 12:45 AM
Yes, it's only about 1 hrs drive south from me. Maybe a little more but not much. I really like that track. Almost never disappointed in the prep.
Old 01-12-2025, 10:35 AM
firechickenman's Avatar
firechickenman firechickenman is offline
If you can get that to work on a radial with the power your making my hat is off to you! Not saying it can't be done, but I gave up on my similar set up at a much lower power level and went with double adjustable shocks on the rear and then hybrid coilovers with double adjustable shocks on the front a few years later. Both made a huge difference! I was hesitant to go with DA shocks because I thought I would get "lost" in the adjustments. I was a pretty short learning curve and I wish I had gone to them sooner!
Any plans for a drag and drive event this year?
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
Old 01-12-2025, 11:29 AM
I do wish I had bought the double adjustable shocks. But I'll give it a shot with these.
As far as Drag and Drive events, that is my goal. Just have to make sure it's reliable, then find an event close enough to me
Old 01-14-2025, 09:37 PM
I got a drop base air cleaner and am making a new air pan, I am hoping that the drop base will help smooth out the air going into the carb in place of the old air pan which was just a flat piece of aluminum sitting on top of the carb. Still have to add the rubber seal to the lip where it mates to the underside of the hood.
The Following 2 Users Say Thank You to Scott Stoneburg For This Useful Post:
Thread Tools
Display Modes
