Old 01-12-2025, 01:53 PM
chuckies76ta's Avatar
Default Hydraulic Clutch Master Cylinder Upgrade
Hi: I'm curious if anybody has upgraded to a hydraulic clutch system from these guys.
https://www.malwoodusa.com/hydraulic...et-reservoir/#
I have the early style from American Power Train and had issues with the cylinder piston leaking from side loading. I replaced the cylinder and made a bracket to prevent the side loading and has been fine. No leaks.
I like what these guys have done with a complete support bracket at Malwood.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 01-12-2025, 10:36 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
I have the new all in one under dash unit from American power train for my 66 lemans. I haven't ran it yet but fit and quality are top notch.
66 Lemans build https://forums.maxperformanceinc.com...d.php?t=876235
Old 01-12-2025, 10:58 PM
Thanks for posting. They are the same units that American P.T. sells. Like you say looks top notch.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Thread Tools
Display Modes
