Old 03-03-2025, 11:41 AM
chuckies76ta's Avatar
Default Cometic Heads Gaskets
Hi: Just changing some head gaskets on a 455 bored .030. So 4.181
Does a cometic gasket with a bore 4.200" sound right?
Charles
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 03-03-2025, 12:07 PM
John Langer's Avatar
John Langer John Langer is offline
They can make any bore, thickness or water hole pattern you want.
The Following User Says Thank You to John Langer For This Useful Post:
Old 03-03-2025, 12:10 PM
Yes I understand that. Just want to confirm the bore size was correct. I have that new set of gaskets in the picture. Getting old here. lol
Thanks for replying.
Old 03-03-2025, 05:09 PM
charlie66's Avatar
Charles
As long as it doesn't overhang the bore its good. I run a 4.200 and have found to also check to see if it overhangs the combustion chamber on the head.
My Half AN Injun.....
The Following User Says Thank You to charlie66 For This Useful Post:
Old 03-03-2025, 05:42 PM
Ok, I will watch for that when I check them on the block. Thank you.
Old 03-04-2025, 07:09 AM
charlie66's Avatar
Because i had my head milled there was one area on the combustion chamber that the gasket over hung, because when you mill a head, the chamber starts to get wider. If you have 2 dowel pins you can locate the gasket on the head to determine if it fits ok. I got lucky and was able to trim it without getting into the sealing ring area.
Old 03-04-2025, 09:15 AM
Thanks guys. I got it all figured out. Talked to Dave and he pointed out somethings about the gaskets that I had never paid attention to like the valve relief area. I appreciate the help.
Charles
Thread Tools
Display Modes
