#61
Old 03-30-2020, 03:07 PM
exotec exotec is offline
so, all parts found: Pistons, Rings, main and rod bearings, intake and exhaust valves, timing belt, gasket rebuild set.
Jerry was a big help as well the overhead cammers club!
serwas
Karl
follow my project on instagram
  #62
Old 04-04-2020, 02:25 AM
Twinshadows Twinshadows is offline
Hey Karl ………..
"it's Me" !
I see your picture of your "broken exhaust manifold" . ………………..
so, Look up " Marine - Tex " ……… a two part mix , "thick putty kind of paste" , and I've used it for years : to patch 'gas tanks' , Big electric motors , AirPlane Props ( wood two blade props - - for "air boats" ) . So as thick as the broken spot , I think it would work (for a 'cruiser motor' ) , if "the broken area IS CLEANED properly " . . . . . . and would be worth a try.
We used this stuff back in my body shop days - - - mostly too repair those front "Fiber-glass Header Panels" on the Olds 88 & 98 , some boats , ect.
Last time I looked it was $$$$ , so look at it , and if nothing else - - - it would work until you could find a replacement.
I buy the Gray Product in a Qt. size can …………………………..
and, on the older cans - - - the label even stated : can repair
"cracked engine blocks" . Keep clean & sealed - - it will last for 5 - 7 years.
http://marinetex.com/products/marine...x-epoxy-putty/
I'm just saying . . . . . jim - - - - (it's been my "go - to " product for years ) .
  #63
Old 04-04-2020, 02:37 AM
Also, I have used "Marine Tex " on my Nova Gas Tank to plug a hole , back in 2010 (still there & NO LEAKS) .
I have my Dads old 53 International p/u that I had cut open the side of that gas tank , for repairs, and "patched that tank - - - back in 1978 , at that body shop" . I even tried "fiberglass tank repair kits" for patching fuel tanks - - - - - they Do - Not hold up = = = = = = = = This stuff WORKS .
THAT's 40 PLUS Years on my IH gas tank …………………………………. and, it's hard too find something that holds-up to 'gas tank repairs' . . . .. been there .
Just clean your part GOOD , and MIX Properly …………. build it up higher / thicker , and machine or sand down too correct level .
jim
  #64
Old 04-04-2020, 03:20 AM
HI Jim,
nice to meet you here as well!
Thank you for the recommendation, I'll have a look!
serwas
Karl
  #65
Old 04-10-2020, 07:51 AM
maybe a bit too early compared to the status of the rest of the car, but Slavko, my mate from the upholstery shop has same time and started with the work on the bench seats!
the additional wire will/shall improve the stability
both seats will get more lateral guidance
front bench seat:
rear bench seat:
He is doing a lot of jobs for vintage Porsches and therefor he has access to original Porsche fabrics. So we decided to use Porsche Pepita for the middle section and black leatherette for the rest - will almost look like new from Willow Run delivered
serwas
Karl
  #66
Old 04-12-2020, 04:46 PM
U47 U47 is offline
Classic X/F sub-frame, nice! And that's some sway bar you have there.
Not Exactly, from 1975-79 X body the answer is yes.
A 1973 F body Camaro or Firebird would be a FRONT STEERING car. A 1973 NOVA / Omega / VENTURA / APOLLO would be a rear steer car.
1975 is the magic year for X bodies because they will now become front steer like the F body cars and have wider tracks.
1973 Omega has a 59.1" front track
1975 Omega has a 61.3" front track
1973 Camaro has a 61.3" front track
1973 Omega / Nova is still using the old front sub assy. that goes back to 1968, When the 2nd gen Camaro/Firebird came out in 1970 the sub assy was changed slightly to be a front steer and a wider track for the new bodies and better stability control. Also the rear axles changed as well giving the F / body cars a 60" rear track and X bodies a 59" rear track compared to the 1973 Omegas 58.8 rear track.
  #67
Old 04-16-2020, 07:23 AM
my mate finished the backrest of the rear bench seat - this is just awesome!!!
serwas
Karl
  #68
Old 04-16-2020, 08:48 AM
Looks Awesome! My wife would love that pattern, looks very much likes Houndstooth
  #69
Old 04-30-2020, 04:09 AM
picked-up the most parts from the upholstery shop - gorgeous work! he has a real love on details!
serwas
Karl
  #70
Old 04-30-2020, 06:51 AM
They look great!
  #71
Old 05-29-2020, 05:20 AM
took a bit but today the first parts for the ohc6 rebuild popped up.
even if all orders where on the same container from TX to Germany, Jerry and his parts made the race!
Quite happy that I got Jerry named here, was lucky to do business with him - very easy and successful!
serwas
Karl
  #72
Old 05-29-2020, 08:57 AM
Glad it worked out! Jerry & his Wife are good People!
  #73
Old 06-04-2020, 03:27 PM
pistons, rings and main bearings, rod bearings are delayed
serwas
Karl
  #74
Old 06-06-2020, 11:18 AM
Try to rebuild the water pump. Someone mentioned in the facebook cammer group forum Chevy L6 parts can be used. Lets see!
serwas
Karl
  #75
Old 08-23-2020, 02:55 PM
Was posted yesterday on the OCA Facebook page. This is how my olds looked also when it was new and hopefully will once look again.
he just bought it 2 days ago with orig 25k on it 😍😍
serwas
Karl
  #76
Old 09-21-2020, 12:03 PM
Head and block are back from the shop. Now painting it Oldsmobile Gold and polish the cam housing
serwas
Karl
  #77
Old 10-05-2020, 11:43 AM
Is there a clearance issue for the front of the engine with the 68+ Xbody hood the way there apparently was with the 70-81 F body hood?
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
  #78
Old 10-06-2020, 02:33 PM
63 bomb's Avatar
63 bomb 63 bomb is offline
I can't see that there would be... I got it to fit under a stock '63 Chevy II hood.
  #79
Old 10-24-2020, 12:06 PM
painted the parts from the Right Stuff disc brake kit for 14 inch. wheels the last days with POR-15 caliper paint and today finally got it installed! was a quite easy fast forward job.
serwas
Karl
  #80
Old 11-11-2020, 12:41 PM
jmt455's Avatar
jmt455 jmt455 is offline
That's looking great!
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1923 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1968 GTO, 428, THM400, 2.73 posi cruiser
1969 Chevrolet C10 Fleetside, 350, THM400
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
