Old 01-31-2024, 12:08 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Engine 2 Dyno w Custom 12-1 Crank Trigger, Finally Done Correctly
Not gonna get into the 1st engine build mess from a prior thread, but the actual engine aspect is finally over and done correctly. The resolution with first shop will now begin.
Here are the dyno details..
ENGINE SPECS
461ci stroker (forged)
11.7 compression
Tested after pulls, cylinders 205-210psi & 3-5% leak down cold.
Voodoo Hyd Roller 231/239 & 110LS and total lift with 1.65 rockers is .583/.605
KRE High Ports as cast
Holley 1000cfm with 1" spacer
Torker 2 (maybe ported) with flange adapter for KRE
Doug's 1 7/8 headers
Holley HP V5
Custom 12-1 crank trigger, we made brackets
120lb injectors (yes too huge but they idle great)
PEOPLE
Engine rebuilt correctly by Randy at PER in Plainfield IL
Tuned by Don Bailey (he got 7% more power vs 1st tuner)
RESULTS
Chasis dyno
606tq and 569hp
93 Pump
34 degrees timing (Don varies increments to engine need)
High 12s AFR (ratio changes to needs & Don calculates)
-1.6 vacuum @ WOT
After comments....
Timing with 12-1 Trigger was dead nuts vs Dual Sync issues.
It's clear the intake is hurting power, not sure it's actually ported like I paid for from prior shop (sloppy).
I can't believe 93 could safely do this but Don and Randy were confident I'd be fine, it appears so as spark plugs looked good too.
Driving with 550tq+ from 3k rpm through 5500rpm should be fun.
I guess I'm shifting at 6k rpm, no need to go higher really.
Future...
Cars setup for ethanol so I'll do an E map with Don and run E30 to save the $1 per gallon over 93. Possible dyno session to see if E added any power and try a tunnel ram filter base idea vs 3" air cleaner.
ID:	627607   Click image for larger version
ID:	627608   Click image for larger version
ID:	627609   Click image for larger version
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
The Following 3 Users Say Thank You to GOAT8U2 For This Useful Post:
Old 01-31-2024, 12:19 PM
johnta1 johnta1 is online now
Congrats!
Old 01-31-2024, 01:27 PM
Nice power for that size cam!
If you end up doing that possible dyno session and have 1.5 rockers I would love to see you try a pull with them on the exh only.
Old 01-31-2024, 01:41 PM
Stan Weiss's Avatar
ENGINE SPECS
11.7 compression
Holley HP V5
PEOPLE
RESULTS
Chasis dyno
606tq and 569hp
93 Pump
-1.6 vacuum @ WOT
After comments....
Future...
Nice numbers.
Is the injection batch or sequential?
Yes something in the intake track is holding it back -1.6 vacuum @ WOT is to much.
Stan
Pontiac Pump Gas List
Old 01-31-2024, 03:50 PM
70GS455 70GS455 is offline
Looks more like an engine Dyno than a chassis dyno
Sent from my SM-S901U using Tapatalk
The Following User Says Thank You to 70GS455 For This Useful Post:
Old 01-31-2024, 04:51 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Excellent!
Go fast, see Elvis!
Old 01-31-2024, 08:04 PM
ponjohn's Avatar
ponjohn ponjohn is offline
That's impressive.
What trans / convertor?
Old 02-01-2024, 12:47 AM
GOAT8U2's Avatar
Hahaha, I meant engine dyno and for some reason said chasis dyno. WTH
I've heard others say to go smaller on the exhaust rockers, I'm missing something here since you'd assume more lift should be more flow but there's probably variables and velocity aspects I'm not aware of.
Tuner Don changed the fuel and ignition in HP so when I get the tune out of HP I'll know which ones. If I remember correctly he wasn't real excited to see the original tune was not setup correctly and he had to start from scratch and get all the math and voltage etc dialed in. He knocked it out exactly how you'd want in the end.
Still have the TH400 but with the 10" PTC 0 stator and it came in at mid 3% slippage.
Old 02-01-2024, 08:37 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Very nice build! Great info. Really interesting combo of compression ratio/cam/pump gas. Good job sticking with it, should be a LOT of fun. Mine made peak power at almost the same rpm, I've been shifting at 5800 and getting my best et's.
Chris D
Old 02-01-2024, 09:11 AM
mysticmissle's Avatar
I’m Suprised a high port Motor needed 34* timing on pump gas maybe it’s camshaft related or efi related?
My 511 11:1 liked 28-29 w 330 kres
Different 400 hiports on my 540 13:1 on race gas and I’m
In the low 30s both carbed but wildly different camshafts
Might be some
Power and safety moving lower
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-01-2024, 12:17 PM
Jim Moshier's Avatar
Very nice build! Great numbers should be a fun ride!
Jim Moshier
1962 Catalina 389
Old 02-01-2024, 05:40 PM
ponjohn's Avatar
Ok, engine dyno.
Old 02-02-2024, 10:22 PM
R 70 Judge's Avatar
Cool build! Great numbers with such a small cam
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 02-10-2024, 10:56 AM
Tim Corcoran's Avatar
Another Voodoo cam success story, like was already said those are very impressive numbers and an impressive torque curve for a 231/239 @.050 hyd roller.
Tim Corcoran
