Old 07-10-2008, 04:07 PM
1963409 1963409 is offline
Default 62 425A - Motor Details
Fairly new to Pontiacs, Can anyone tell me what is the correct finishes for the following items. I seen them different on some high dollars cars and would like to know what is correct.
1. Are the valve cover and oil pan bolts supposed to be painted engine color or zinc finish?
2. Is the lower crankshaft pulley satin black or engine color?
3. Are the oil breathers chrome or black?
4. Is the water pump pulley black or type of cadium plated or natural finish?
5. Is the oil pump housing natural alm. or painted engine color?
Thanks- Any help would be greatly appreciated.
Mark
Old 07-10-2008, 07:06 PM
Stuart's Avatar
Stuart Stuart is offline
1. Are the valve cover and oil pan bolts supposed to be painted engine color or zinc finish? Engine color.
2. Is the lower crankshaft pulley satin black or engine color? Engine color.
3. Are the oil breathers chrome or black? Black (although I think there's some controversy here...I've seen them engine color as well.)
4. Is the water pump pulley black or type of cadium plated or natural finish? Black. The spacer for the fan is raw aluminum.
5. Is the oil pump housing natural alm. or painted engine color? Not sure what you mean here, since the oil pump is internal to the engine. If you mean the oil filter adapter on the rear passenger side of the block, it should be engine color.
Old 07-10-2008, 09:08 PM
Thanks Stuart,
On #5, that is what I meant, I had a brain fade while I was typing, but I'm glad you figured out what I meant.
Thanks for the help,
Mark
Old 07-10-2008, 09:50 PM
gentile3's Avatar
gentile3 gentile3 is offline
Default code
what is the block code on your 425a?.... is it original to the car?
2007 Chrysler 300 C SRT8
2005 Pontiac G6
2000 Yamaha R1
1999 Chevy Silverado Ext Z71
1998 Ducati 916 SPS
1998 Honda ex300
1997 honda ex300
1997 Mustang Cobra
1997 Sea Doo Challenger 1800
1965 Bonne Coupe 421 3x2
1965 Bonne Conv
1964 Gp 4spd - parting
1963 Catalina Conv 3x2 4sp
1963 Gp 4spd
1963 Catalina post 4spd
1962 Bonne Conv 425a 3x2 4spd
i have an addiction and need help...
Old 07-11-2008, 07:52 AM
Yes it's orginal to car- 62 GP- 11B code-
