I have a line on some old GMC PU's at an old junk yard up here that still have engines. How do I tell if it has a 370 and for that matter how I would know a 370 if I saw one someplace else?
Thanks,
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato |
I can't help much- 370's look simalar to all pontiac v8's , I think that the biggest most noticeable visual difference is the water outlets that come off the front of each head. If I remember correctly ?? I'll look for a picture I took of 32 or 33 three window ford with a 370/dual quad hot rod at Pismo's car show this spring. If you send me your e-mail ,I'll send you a cool engine pic. Lee
If it's a '58 it's a 370. If it's a 55-59 they have water outlets in the heads. How to tell all the early motors apart I'm not sure. I think the 55 and 56 had the Strato Cheif emblem on the valve covers.
Robert Lewis 1959 Star Chief 4 Dr HT dual quad 389 4 speed 1962 Pontiac Plain Jane Catalina http://pontiac-59.com/ |
The block will have a block casting code of 528456.
The date code will probably be useful, also. Engine Codes The block code would probably be the best bet, though, used on only the 370 engines. ![]()
The GMC will have a small bore 336 for 58/59 not 370/389 like the cars.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
Sorry, I thought the GMCs had the same cube pontiac motors except '59. I have a '59 336 in my garage as a spare. I thought it was a 389 until a few months ago.
No engine mount holes on the side of the block.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
here is a pic I think
Correct. 370 was never used in GMC.
Thanks for the info guys! Everyone on here is so full of it... info that is.
![]() Cool picture hellerods! I see what you mean about the water pump. I've got some more engine questions I'll tack on to another post I had going on "287 overbore" in the Street Forum.
Uneasyrider “To find yourself, think for yourself.” ― Socrates “The unexamined life is not worth living.” ― Socrates “Wise men speak because they have something to say; fools because they have to say something.” ― Plato Last edited by uneasyrider; 09-21-2008 at 07:16 AM. |
For info on how to identify Pontiac engine and engine components, see www.pontiacsafari.com/L1Garage/EngineID. For info on Pontiac engines, including the GMC, see http://www.pontiacsafari.com/L1Early...s/V8%20Engines.
Bill Hanlon (GMC Bill) helped with both those articles and I haven't seen him post here lately. He lives in Houston so I hope he survived the hurricane OK. |
Thanks for the info Larry.
That IS CORRECT for 2nd-series-'55 up through '57 GMC (287/316/347 engines). The only GMC difference was lower compression. And I think a different 2-bbl carburetor- Bill Hanlon probably knows about the carbs.
I know my 59 GMC motor has a different carburetor on it. The Pontiacs had the Rochesters. Could it be a Stromberg on the GMC? I can't remember what it is but it has the smaller bolt pattern and a carb adapter to adapt the Pontiac manifold to the smaller carb bolt pattern. This is the only picture I can find. The middle carb is the one from the '59 GMC and the front and rear carbs are '59 Pontiac Rochesters.
![]() Wait here's a better one ![]() And here's a picture of the manifold off the GMC motor. ![]() GMC ![]() Pontiac
Good pictures.
Thanks,
I'm here, just no power at the house yet. Very minor damage and the backyard pool looks like guacamole.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
The GMC trucks used a Bendix/Stromberg WW carb. Most were manual choke, but a few (mostly Subrubans) were auto choke.
Thanks for clearing that up. I'm glad you're OK from the storm
I wouldn't mind having a few more 336s either '58s or '59s. If anyone has some closeby, or can hang on to them. Let me know.
thanks, Steve
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
I'd trade you for a '59 389.
