#61
To add to my above information.
Increased rocker ratio to 1.8 .400 lobe HYD ROLLER. Asked for best power from 4500 to 6500 RPM. Ended up adding about 14 HP to the averages. 268 / 268 @ .050 109 LSA - 107 IC ---------------------------------------------------------- 264 / 276 @ .050 106 LSA - 105 IC ---------------------------------------------------------- 264 / 268 @ .050 107 LSA - 105 IC ---------------------------------------------------------- 268 / 272 @ .050 107 LSA - 106 IC ---------------------------------------------------------- 264 / 272 @ .050 107 LSA - 105 IC ---------------------------------------------------------- 268 / 272 @ .050 108 LSA - 107 IC |
#62
Pastry Chef how accurate is that simulator?
#63
It is excellent to compare trends, used by many pros.
I don't rely on any one tool I have, it is just one more. |
#64
Im just curious why it added 5-9 more degrees just because you added 1.8 rockers
#65
The simple answer is insufficient valve lift is a top end bottleneck. So the bias leans towards improving lower range power to get the best average it can.
#66
Interesting, with a high valve to bore ratio i wouldn't think it would be that lift sensitive
#67
I can say increasing port velocity can reduce the net valve lift required.
#68
The AFR 265's and 290's weren't even around back when I bought my 305's. And while I don't doubt the 265's may be a great head, as I've never seen a junk AFR anything, I'd sure like to see them on the dyno compared to a 305 before I made any claim that they "kill". Coming from a lot of years using the 305's myself they do a pretty damn good job on a little engine. It's for these reasons a wide port that is said to be about 275cc wouldn't scare me in the least on a 461 Pontiac, especially with a 4.210 crank. |
#70
Not enough to sway me in a decision either way. I've never been of the opinion heads in this range are too large for a 450-470 ci engine based off what I've done with them in a street car.
Just an FYI, the 305's turn into 315's with the CNC port option. So your nearly into your port dimension comparison with very little CC gain. |
#72
Pasty Chef can you run a cam similar to what Stan should from 4500 to 6500 like the others. Just wondering how it stacks ups
#73
Going back to the op's first post/ question, it's not a matter so much of the Cam specs to run,but gearing!
Even with Enough effective Caming to make good use of those heads to the tune of 70% of what they can do, your taking about a torque band even with 461 cubes under the heads that does not really shine until 4000 rpm On the street you want a minimum of a 5 speed manual trans and 4.11 gears assuming a 28 to 29" tall tire. |
#75
Or are you saying people should turn there e-heads 9000rpm with stainless valves? |
#76
You don't even need that much.
I run a very snug driving Continental in mine that flashes around 3400. Remember this is a street car in the street section, with a small camshaft. There is no need to run a 4500 stall. With the big heads and little cam mine makes peak torque at 3900 and is extremely flat from there and makes peak power at only 6300 rpm. It's a very broad and flat curve with a nice spread between the peaks, despite what some say it should be with large heads. Even with the tight stall it still pulls the wheels and runs 1.5 short times in a 4100 lbs. car. It's still a docile street car. Actually the snug stall works to my benefit, flashing just below peak torque, even though it's still in the 500's at that point, makes it a bit easier to launch and manage the heavy car on the small 275 radial tire I run. In a Pontiac with a much longer crank for the cube size, a snug stall like this should be even less of an issue. Everyone talks about how much torque their Pontiacs make, it shouldn't have a problem carrying it. Last edited by Formulajones; 08-10-2020 at 09:32 AM. |
#78
Sure, I can post results tonight. For best accuracy if you can provide the port minimum CSA and CSA at port entry. |
#79
Butler wide ports are roughly 3.35 from entry to pushrod
#80
What was the projected average hp for this group of cams?
Illinois Outlaw Gassers 6.27@107 9.97@131 |
