Old 05-29-2022, 08:33 PM
duke455's Avatar
duke455 duke455 is offline
Default Sec gen manual steering box question
What's the best manual steering box out there to swap onto a 73 Formula ? GM or aftermarket
Old 05-30-2022, 01:10 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Easiest swap it the 4 bolt cover S-10 box. I think mid 90s. The PS pitman swaps right on.
Skip Fix
Old 06-03-2022, 03:28 PM
grandville455's Avatar
grandville455 grandville455 is offline
I have a manual one off my 74 if your interested?
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 06-03-2022, 05:24 PM
FrankieT/A's Avatar
Monte Carlo SS from the eighties
Old 06-03-2022, 09:20 PM
AG's Avatar
AG AG is offline
A Monte came with manual steering?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 06-03-2022, 10:35 PM
Our host has new ones for sale; if they are anything like the Delphi box in my T/A it should be superb.
https://secure.amesperf.com/qilan/De...A&web_access=Y
Old 06-04-2022, 09:44 AM
Skip Fix's Avatar
I wonder which Pitman that one takes.
Skip Fix
Old 06-05-2022, 05:48 PM
FrankieT/A's Avatar
Sorry, I didn't realize we were talking manual...
Old 06-09-2022, 06:30 AM
455firebird1969's Avatar
I知 in the same boat, owning. 1974 Firebird with a PS gear installed in a race car. The PO said he ran it disconnected which I guess would work for drag racing, but it seems like a lot of extra weight to put up from needlessly.
I知 planning on swapping in a manual steering gear.
Which one is lighter the OEM manual box or a mid nineties S-10 box?
Does anyone know an aluminum steering gearbox that would work? At this point I知 just looking for options.
Old 06-09-2022, 09:21 AM
Skip Fix's Avatar
My understanding is unless you have a light car do not use an aluminum box. Factory F body manual boxes also I think took a different specific pitman arm.
Skip Fix
Old 06-09-2022, 10:26 AM
i've got the whole manual setup off my 74, pm me if interested
Darby
Old 06-09-2022, 11:28 AM
77 TRASHCAN's Avatar
Darby, what are you using now???
Using a power box without the pump can be dangerous, it's difficult to turn a power box with no assist, for even the strongest person.
Shut it off
Shut it off
Old 06-10-2022, 08:36 AM
I put a rack in from TRZ a few years ago
Darby
