Just thought i would let everyone know I posted a wiring diagram in the electrical tech section for 70 gto/lemans owners. alot of the info will be the same for 71-72 also but not everything.
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
GR-RRR!
was it like this?
1968 Idiot Harness Black BRAKE Pink Power dark blue OIL light Blue L-blink gray dashlights Brown GEN dark green TEMP tan FUEL gray dashlights nc med Blue R-blink light green HI BEAM 1968 Idiot POD BRAKE Pink Power dark blue OIL light Blue L-blink gray dashlights Brown GEN dark green TEMP tan FUEL gray dashlights nc med Blue R-blink light green HI BEAM 1968 Gauge POD BRAKE Pink Power dark blue OIL light Blue L-blink gray dashlights tan FUEL dark green TEMP Brown GEN gray dashlights nc med Blue R-blink light green HI BEAM 1972 idiot Harness tan Pink Power dark blue OIL light Blue L-blink gray dashlights tan FUEL Brown GEN dark green TEMP gray dashlights med Blue R-blink light green HI BEAM Black BRAKE TYPICALLY: swap 5 and 7 GEN and FUEL wires But the 72 Harness is excitingly different: shift 1 to 12 swap 6 and 5 shift 3 to 2 shift 2 to 1 check extra tan 12, can put in slot 3 nc.. Half-Inch Stud "tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs 11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs 12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
