Old 03-25-2021, 12:19 AM
Shift'n Gears's Avatar
Shift'n Gears Shift'n Gears is offline
Default Shaker / Scoop for 1977, 1978, 1979 Pontiac 400
Original Shaker scoop for a 77-79 Pontiac 400 engine. Shaker is in good condition with no cracks. Original drain nipple is in good condition. It does have a couple layers of paint on it and there is the typical glue in areas where the foam seal goes. More pics upon request. Asking $225 + shipping OBO
ID:	563297   Click image for larger version
ID:	563298   Click image for larger version
1978 Y84 4sp
1979 T/A 400 4sp Blue/Oyster (special order)
2000 T/A WS6 6sp Black/Black
Old 03-25-2021, 03:05 PM
78w72 78w72 is offline
FYI: 77 shakers are different than 78-79, they have a much lower profile height.
that looks to be a 78-79.
Old 03-25-2021, 06:51 PM
78W72 - You are correct. In 1977 when the Shaker style changed from the 70-76 style, it had a much lower profile and had a ridge going up the center line o f the shaker.
However, over the past 25 years I have talked to several owners of low mile original 77 TA's with late build dates (May - June) that had the Higher profile shaker and they told me the shaker was original. In my search for a S/E I went to look at 2 unrestored 77's that also had the taller shaker. Could they have been changed? Sure. And if it were one case, I would have just thought that it was replaced.
Seeing 7-8 77's with the taller shaker makes me think that it is possible there was a changeover prior to 78, but I have found no documentation for it and only the word of the owners. If anyone has more information about the use of the shakers and the changeover point I would really like to know. But the low profile shaker with the ridge was definitely only used in 77.
As far as fitment goes, this shaker will fit 77-79 W72's, though not correct for most 77's as you point out.
1978 Y84 4sp
Old 03-25-2021, 07:01 PM
yeah i figured you knew that, just wanted to mention it for anyone with a 77 that didnt know & needed the lower profile.
good luck with the sale, looks like a nice one.
Old 03-30-2021, 06:08 PM
Sold !
1978 Y84 4sp
Old 04-03-2021, 01:51 PM
pippintook pippintook is offline
Hey Shift - pretty sure you are right about the taller shaker being used on late build 77 TAs. I always thought all 77 TAs had the low profile shaker. But, I think pontiac switched to the taller shaker starting late in 77 model year (possibly around May 1 1977?). I cant recall where I read it - dont think it was Rockys TA book - but did read somewhere.
Old 04-09-2021, 02:33 PM
Thanks for confirming that the change was late 77. If you ever find where you read it, I would like to document it for my notes.
Thanks!
1978 Y84 4sp
Old 04-09-2021, 10:28 PM
Elarson's Avatar
Elarson Elarson is offline
I had a '77 (that I bought in '78 from original owner) with the low profile scoop. It's serial was 197624....so a switch to taller had to be after that.
FWIW,
Eric
The Following User Says Thank You to Elarson For This Useful Post:
Old 04-10-2021, 09:50 AM
burd's Avatar
burd burd is offline
I think there’s a 77 bulletin on up this, look in a 77 binder.
Just Say No To 8” Flakes
F ire B irds
Old 04-11-2021, 07:23 AM
77 Canamman's Avatar
From an old post:
Originally Posted by Y81all View Post
The early low-profile shaker with the pronounced center ridge was used until the May/June 77 timeframe when it was switched to the more common taller shaker we're all familiar with. Specifically the switch happened on 5/19/77 for the 400 powered cars and on 6/02/77 for the 403 powered cars (presumably because they each used a unique shaker). This info courtesy of John Witzke.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
