'67 & '69 Firebird Brake Boosters
Hey Guys...
I am usually on the '70-'73 forums, but a friend has asked me to help him restore the brakeboosters on a '67 and a '69 bird. Both have power brakes.I need to know what the booster codes are for the '67's and the '69's. These are the codes stamped on the rear of the tab at the 12 o'clock position. For instance, the 1970's are 0426 and the 1971's are 1957..... Does anyone here know the correct codes for the '67's and the ''69's?? He doesn't have the originals and we need to start looking for the correct coded boosters..I appreciate the help.. |
The 69 booster number is 9227.
69 Z 302 M21 3.73 http://www.byjanmarie.com/camaro/Z28.html 69 FB 400 http://www.byjanmarie.com/firebird/69.html 69 Camaro 327 4sp. 4.10 http://www.byjanmarie.com/camaro/69camaro.html ( SOLD) 2002 Camaro LE/SLP-(sold) 1967 Nova SS-- 327, M20, 3.73, FRT Disc |
Nashcar-
thanks for the response. It really helps. I will also need the master cylinder pad stamping?? Is the 69's the same as the Camaro-US?? |
Heres a pic of a 67 Tempest booster and MC
If you cant read it its code 48. If you want it with MC ,its yours for $50. I believe that F body and Tempest both used these 2 parts. I have some 69 F body MC but dont see any code on them. |
The Following User Says Thank You to Cammer-6 For This Useful Post: | ||
How about that. I never noticed a number there before. Realize you don't need it for the question but my '68 has only an "8" stamped there. If I could ever get the one elusive last bolt loose from the firewall, I'd replace it with a new one I have.
The numbers on the front of that tab(facing foward to engine compartment) is the day of the year the booster was assembled.Like the 48 is the 48th day and the 8 is the 8th day. There is a number on the other side of that same tab.That is the model yeer specific booster code that I am looking for.
And CAMMER-6, I will take the booster/MC set up. What is the code on teh rear of the tab with the 48 on it?? PM me with payment instructions.. |
2945 is # on back
I have 2 of them one has MC with bleeders the other without both have rust pitting on the lower half of the outer shell. |
67 is the same as Camaro - 0749 (drums) and 8515.
69 is 9222 (drums) and 9227. http://www.camaros.org/suspen.shtml#Brakecomp |
The Following User Says Thank You to Kurt S For This Useful Post: | ||
Kurt- really thanful for the information.That is just what I needed..
No problem. Sorry I keep linking to the Camaro data, but so much is common.
Pontiac must have wanted a different brake feel in 69 so they used different boosters. |
i think the boosters are the same, just different numbered casings.at most the springs inside the booster might have a different rate,everything else is identical.. anyway, thanks again...
I can check m/c and bstr on my 67 FB late tonight.
4 piston disc. Owned since 75, and look original.
1st digit on booster is half on/off.
My guess is 8515. Could be 3515 or B515. The top half of digit is smaller then the bottom half. M/C has 5460346 on 1 side. D4 on the other. If theres any more codes somewhere on it, let me know. I'll clean it up and check.
The spring is different in the booster, so the response is different.
Anyone know what a 9391 coded booster goes to?
Thanks to Steve Gregori ... it's a Chevelle number.
He's great with booster restorations and plating.
My old '69 master
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
