Old 01-27-2009, 11:06 AM
bpc bpc is offline
Default Timming setup for pontiac 461
what direction to advance or retard timming on pontiac engines...example do you turn the distributor towards the fire wall for retarding our towards the radiator front location for retarding..
Thanks.....
Old 01-27-2009, 11:13 AM
wheelspin's Avatar
Arrow
The distributor rotor turns counter clockwise, so rotating the distributor towards the front of the car (counter clockwise) will retard the ignition timing.
Les
Les Iden
Old 01-27-2009, 11:15 AM
bpc bpc is offline
Thanks for the info
Old 01-27-2009, 11:19 AM
Murf'sDad's Avatar
Murf'sDad Murf'sDad is offline
A counterclockwise turn will retard the timing. As to turning it to the front or rear you have to have a reference point. Use the vacuum advance canister as the reference. Turning the vacuum advance toward the firewall will retard the timing. Turning it toward the front will advance the timing.
Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi.
“Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill
Old 01-27-2009, 11:47 AM
Stewart
IF you have the vacuum advance on the drivers side of the engine.
Thought I'ld add that, since they tend to get dropped in different ways.
AND drivers side is factory.
Old 01-27-2009, 01:54 PM
Murf'sDad's Avatar
Thanx. I should have added that. Never assume some one has the body oriented to the stock position.
Stewart
Old 01-27-2009, 03:42 PM
gjn gjn is offline
"68 Firebird 461
Send a message via MSN to gjn
Thanks.....
FWIW, my 461 likes 30 degrees of total timing (12 initial + 18 mechanical).
GJN
1968 Firebird 400
461
3,580 LBs
3.2k Stall
3.25
1.657 - 60'
11.637 @ 115.45
http://www.youtube.com/watch?v=dEqzw...e=user&search=
