Old 08-29-2017, 03:00 PM
zephyrracer zephyrracer is offline
Default Exhaust manifold grease
Anyone ever hear of a grease you can put on your exhaust manifolds turning them silver,
Friend of mine was at a show and and talked to a man that used it problem can't remember the name of the product all he remembered is it comes in a small tube and you put a dab on your finger and rub it on
Thanks in advance Gregg
Old 08-29-2017, 03:26 PM
Icefan71 Icefan71 is offline
I remember reading somewhere about painting them with anti-seize. Never tried it, though. It'll probably stick, but it sounds like a messy, and probably smelly job when it gets hot.
1972 Pontiac Lemans 350 Qjet Summit 2800
Old 08-29-2017, 05:13 PM
lemansboy70's Avatar
lemansboy70 lemansboy70 is offline
I believe I saw that on Eastwoods site.
30+ Years with NAPA. Happy to help with any auto parts questions.
Old 08-29-2017, 05:24 PM
GT182's Avatar
GT182 GT182 is offline
I do know motor oil will clean them up. When I got my GTO back in 2007 the rings were broken on 4 cylinders and the blow by came out the air breather cap on the right side valve cover. All that oil hitting the right side exhaust manifold cleaned it up nice and got rid of the rust. I'm not saying soak the exhaust manifolds with oil and run your car but it does work. I know that for a fact.
Anti-seize will be the same mess as motor oil. Smoke and all, but it should work. Just use a rag it lightly coat the manifolds and see what happens. But do it out of town on a back road that doesn't get much traffic so no one sees ya.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-29-2017, 05:32 PM
njsteve's Avatar
njsteve njsteve is offline
The stuff was called Calyx. I used it once and it does work nicely but needs to be reapplied once in a while which gets kind of difficult in a tight engine compartment. The stuff gets on everything just like antisieze.
http://www.eastwood.com/calyx-manifo...ting-3-oz.html
Old 08-29-2017, 06:46 PM
Stuart's Avatar
Stuart Stuart is offline
Another possibility is stove polish or stove black, it's the stuff you rub on a wood stove to make them look nice. Stores that sell wood stoves or fireplace inserts should have it.
Old 08-30-2017, 08:18 AM
Andre's Avatar
Andre Andre is offline
Calyx is the product that the Corvette guys have been using for over 20 years.
Old 08-30-2017, 09:39 AM
I was going to use some of that but decided I'd go with the original exhaust manifold finish...Rust.
Old 08-30-2017, 11:37 AM
GT182's Avatar
That's how mine is too Greg. LOL
Gary
