Old 04-24-2023, 04:25 PM
mysticmissle's Avatar
Default 15'' steel wheel and poverty caps on a 1969
i am looking for a 15x8 w 4.5'' bs steel wheel that will take either an original or a repro pontiac poverty cap. I had been told wheel vintiques offered such a wheel but i do not see anything with the correct style for the poverty cap.
I am putting 275 60s on them, will a 15x7'' work if i find a 3.5-4'' bs?
thanks in advance
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-24-2023, 04:44 PM
AG's Avatar
AG AG is offline
A 15 x 7" rim with stock BS (4.25"?) will work, I have WV Rally IIs with 275/60/15 on my '72 A-body.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 04-25-2023, 03:24 AM
You want a 4.75" bolt circle. 4.50" is Ford or small Mopar.
Old 04-25-2023, 01:18 PM
bs is back space not bolt circle. looks like us wheel has a few options and are in stock wheel vintique appears to be out of stock for months
1964 540 gto
Old 10-07-2023, 11:04 AM
69FIREBIRD76MM's Avatar
Default Dog dish caps
Wheel ventiques style #62, 15x8", 4.25" back spacing will fit the bird with poverty caps. Also you can buy 15x5's, 205--70-15's will look great.
ID:	621204   Click image for larger version
Old 10-08-2023, 11:21 PM
turbo69bird's Avatar
That looks really good thanks for the sizes - may do this on my convertible .
Wish there was a 15x8 I could put a 14 69 bird hubcap into.
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
