Old 02-14-2015, 12:43 AM
guidos's Avatar
guidos guidos is offline
Default Procharger aluminum block, coming together!
Here is a picture of the basic rotating assembly and of the new bearing grade camshaft thrust plate.
The rings are a diamond black SS high heat high impact ring set, ¾” groove main bearings and a brand new product, high load rod bearings specifically designed for boosted engines. Of course there is the beautiful CP boost friendly dished piston.
All this is for my MR-1A aluminum block 4" stroke 4.25 bore..... Perfect valentines gift! Lol
ID:	390171   Click image for larger version
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017!
Old 02-14-2015, 09:20 AM
Awesome!
Can't beat that for a perfect Valentine gift!
Old 02-14-2015, 11:44 AM
Fast 69's Avatar
Fast 69 Fast 69 is offline
What crank are you using?
Old 02-14-2015, 02:09 PM
guidos's Avatar
Forged Scat 4" stroke 3"mains
Old 02-14-2015, 03:47 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Lookin good man!!!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 02-14-2015, 04:58 PM
Tom Vaught's Avatar
Boost Engineer
Mighty Pretty, Richard!
You will really hear the Boost Song with that bad boy!
Tom V.
Old 02-14-2015, 05:31 PM
guidos's Avatar
Thnks Brian and Tom, can't wait. Honestly I was disapointed in my performance at drag week, sure wasn't the engines fault, mostly driver, I have a Slider clutch from Ron Youngblood, one of his dual 8", should get my 60' back and hold the power. Really hoping I will drive it to drag week and run 9's without issues.
Old 02-14-2015, 05:40 PM
67'7F6'Bird's Avatar
67'7F6'Bird 67'7F6'Bird is online now
This Build is Exciting and after talking with you today my Build may incorporate some similarities.
Looking forward to more posts.
Steve
Old 02-15-2015, 07:52 PM
I'm envious! Nice "gift"... Good luck with it.
Old 02-15-2015, 08:57 PM
wreckmastr's Avatar
Nice pieces for sure! Good luck with everything and keep us posted.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 02-16-2015, 09:16 PM
chuckies76ta's Avatar
Looks good Rich. Can wait to see this bad boy at the track
Charles
Old 02-20-2015, 04:11 PM
JC455 JC455 is offline
Oh my Lord, that is BEAUTIFUL!!!!
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
Old 02-20-2015, 04:21 PM
How many aluminum block engines will be running this year?
2 or 3?
Awesome job on it.
Old 02-24-2015, 09:48 AM
Nicks67GTO Nicks67GTO is offline
WOW! Thats awesome
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
Old 02-25-2015, 03:56 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Pistons look to be darn near as heavy as the ones going into my hemi four. What engine speed do you have in mind? Crank have 8 counterweights?
Old 02-25-2015, 09:53 PM
guidos's Avatar
Jack I am not sure of the Crank, Mark at LPI is putting it together. I am hoping 7000 RPM wont be a problem even though I don't plan on spinning it that hard. Also not sure of the weight of the pistons. Mark might jump in here and answer.
Old 09-21-2017, 08:35 PM
wreckmastr's Avatar
Any updates?
6.98 @ 199mph
4.53 @ 164mph
Old 09-22-2017, 02:11 AM
Originally Posted by guidos View Post
... a brand new product, high load rod bearings specifically designed for boosted engines...
Tell us more about those bearings.
Old 09-22-2017, 08:00 AM
Tom Vaught's Avatar
Boost Engineer
Congrats again, on your benchmark at Drag Week this year.
So much effort went into getting a durable package for you to compete properly.
A great deal of that effort came from Mark at Luhn Performance. Many do not know that.
The dedication you showed to getting to where you are today (and at Drag Week) is amazing. If people knew the whole story about that effort.
Good Job! You drove a lot of miles with your GTO this year and did very well.
Tom V.
Old 09-22-2017, 07:14 PM
Hooter's Avatar
Hooter Hooter is offline
Rich is the King/iron Man of Drag Week. Irregardless of brand, Rich puts more effort into his car than anyone.
67 Bonneville ragtop
