80 amp bracket and pulley
looking for a 80 amp set up
I have a 80 amp alt and power steering setup off a 73 455 if that's what your looking for?
Post a pic of what you have
PM me a cell# or email if you want and I will send.
and
I think there is 2 different set ups...
I just dont have a complete one is there a stationary style like my first 2 pictures and uses that tentioner pulley you have in your picture and the adjustable alternator for the 80 amp in my second picture ? Scott |
I need the tensioner pulley and brackets like I pictured.
So you think 71 was a one year only setup on the drivers side?
Are you looking to up your alternator output and are you trying to keep your car original looking? If your not to worried about originality, the 105 amp alternator from a 1990 corvette is 100% bolt on(except for pigtail), charges at an idle(bright headlights at an idle) and looks similar to the original.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Thanks but I want the factory setup
PM sent.
The stationary 80 amp front mounting plate along with the idler pulley was used on '71-76 F-body's, as well as '71 Pontiac A-bodys built up into mid April of '71. In mid April '71, 80 amp equipped '71 A-body's began to be assembled with the front alt mtg plate w the adjustment slot.
Minute detal wise, the alum pivot block changed part numbers, & at least two different design stamped steel pulleys were used as idler pulleys. the latter being able to have its small bearing removed & replaced.
The Following User Says Thank You to 'ol Pinion head For This Useful Post: | ||
I found one. Thanks for the help
