rings,bearings and a couple gaskets.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
youll lose some compression and may encounter some pre detonation with the extra squish area.
Thoughts?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
I'm going with the thicker aftermarket head gasket as it'll help drop compression some for today's gas. On my good engine I'll zero deck the block and the quench distance should be about right with the thicker gasket.
On my e-bay gasket set the cam housing gasket is paper thin, I can't imagine using a thinner gasket than what is in the kit. To directly answer U47's question, it uses the BOP bellhousing.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
