#461
Hi Ed
I know you've seen my cam spec's before so I dont need to post them. But my e-headed engine with a victor port-match only intake, and heads that I was told only flowed around 320-325cfm and 1.65 rockers made 1300+hp at 4300 rpm's. Im positive I would have made close to 1700 had I not hurt the heads. I was hoping for much more though.. Even if you heads flow less than the 367cfm Im sure it will make the power. Keep in mind my headers are 1.75" tubes and my turbo's are T4 housings and only 78mm inlet on 507ci. I will dyno my engine N/A next time just to get a comparison. But my new heads flow 400cfm so Im hopefull it makes 700hp+ with no boost. Good luck, hope to see some dyno runs soon. BTW, I still have a empty seat for drag week. But it wont have the tt engine in it.... boring...LOL |
#462
Agree JDW_Poncho, Another example would be Marty Palbykin with a 240 cfm cast iron head making 1400 lbs/ft of torque at ~4500 rpm and around 1400 horsepower at max rpm before he went to the e-heads. It is all about mass flow thru the engine not necessarily just cfm at a given point.
With a turbo, you need to pay attention to the boost ratio. How much boost vs how much turbine pressure. If the inlet system is too small the engine will make great power and then go flat on any additional power. If the exhaust system is too restrictive you will choke off additional power the engine could have made. You want both sides to be "Happy, Happy, Happy" as Phil Robertson (Duck Commander) often says. You guys are in the very early state of ASSUMPTIONS. (Everyone has one) One piece of DATA is worth 1000 times what one assumption is worth. No one hits it exactly right on the first go thru. They might hit it right more often with many years of experience in boosting (but I still make changes constantly at work to fine tune stuff). If you are not willing to change stuff you are stuck at a point in time. JME Tom Vaught
#463
I would think a turbo engine setup would NOT make as much HP as a N/A combo alone?
#464
The turbos were sized by Turbonetics based on the expected NA numbers. We’re 90hp off. With all the experts involved in this build, I think asking where the 90HP might have been lost is a fair question. Is it as simple as the cam is too small for this size engine or something else? |
#465
I can tell you that a cam setup for a turbo will definitely not make as much HP as a N/A engine.
(let alone the CR and other parameters) I don't see how having a set amount of HP N/A matters compared to what the turbo setup will make? Now if you/they had dyno'd it with the twin turbos and it 's HP was only 1000HP or something, then I'd be bitchin.
#466
Ok, I will take the blame, Ed, Dave Austin asked me what the Aluminum RAV head might flow at .700 lift and I said I thought it possibly could flow 400 cfm, maybe more with more lift.
So he takes the number, multiplies by 2 and gets 800 hp and subtracts 50 HP (if you didn't have the right camshaft or the numbers are off a bit), so his NA HP starts at 750. But you don't have a 400 cfm head, You don't even have a 367 cfm head actually on the engine because of your valve lash and rocker arm deflection. You say that at .600 lift the head flowed 349 cfm. So I will give you 358 cfm before the lash taken out and the deflection. In reality, on the dyno you probably had a true 350 cfm head. 350 X 2 = 700 hp with the right camshaft and compression ratio. But you do not have the typical compression ratio the NA engine would have so we subtract 4% for the lower compression ratio. Now your projected number is 672 hp. You made 660 Horsepower on the dyno. With-in 10 hp of normal Engineering Assumptions using real camshaft lift projections and real cylinder head flow numbers vs the 400 cfm head numbers I gave Dave. Blame me. I assumed that you would have a better head on the engine. The cam might be costing you 10 hp. You are expecting an unrealistic HP number NA for what you actually tested with on the dyno. Tom Vaught ps I have hit with-in 10 HP on several dyno "What Ifs" people have posted on the board.
#469
Ed, any flow numbers with intake and carb attached? Considered another intake?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
#470
Do you have to drive on the street to participate in dragweek? Are you going to change your valve springs when driving between the various race tracks? No functioning TT for dragweek? Can we at least put 2 in the trunk? |
#471
Any updates on your 620 RA-V project? What size valves are you running and do you know what your rocker stud spacing is? |
#473
Most guys do not change valve springs, they put a lower ratio rocker system on the car for driving between tracks, (like a 1.3 ratio rocker arm). Turbos will see very little mass flow with a 1.3 rocker ratio so will be happy on the road. Tom Vaught
#474
I agree on the NA vs. turbo cam HP numbers. The engine with Holley Dominator EFI “tuned by Holley engineers” and turbos was supposed to be dyno tuned before being shipped to me. |
#475
At this point the heads flow what they flow.Fix the important things and put it back together and see what she does.
I think its going to be an ANIMAL! My 4 cyl head flowed 325cfm @ 600 my max lift is 582 and its making 700+ hp. If my 4 cyl 198ci can do that i think your V8 535 will make 1600+. Worst comes to worst , turn up the boost some. I love what you're doing and whish you the best of luck. I can't wait to see what it makes. What ever it makes ,it will me more then most.... Good luck...... |
#476
That is an interesting comment. Tom Vaught
#477
404 @ .700 Im no cam expert so Im not sure how that duration will affect HP. But your right, your engine has a smaller less aggresive cam for the street. If it was built for racing Im positive you wouldnt have had a small cam. Hell no Im not changing valve springs...... thats just because Im not taking it. My little motor might now handle the extra weight with them sitting in the trunk. Just looking for anything positive about your project that I can find. Hope to see it on the street next year. |
#478
Maybe Ed and I can meet up with our TT cars next year at D/W. |
#479
Let me clarify that: The engine was supposed to be run on a dyno with functioning EFI and turbos. I don’t believe this would have included changing turbo housings.
#480
Did I miss anything Joey ""jerzfabguy\IndyCartel"" or did you happen to look at a few of the pictures? |
