#61
TAFF2, THAT IS A OUTSTANDING EXAMPLE OF FABRICATION!
Very nice work there. Buick manifolds had a design that somewhat resembled what you have done and I always wondered why OFFU never offered a similar runner design for the Pontiac (with the Port Devider). EXCELLENT ATTACK ANGLES! Tom V. Did you also mill away the Head runner divider to the head bold boss?
#62
I didn't realize that you could cut the dividers out and have it still work right! Very interesting. I just learned something . Thank you!
My Half AN Injun..... |
#63
I would do as Bruce said and go at least 1.5 times, personally with a 4 cylinder engine I'd start at twice as big. The 4 bangers need all the plenum they can get and with the pulsing I can't imagine it helping the turbo vanes any? How is the turbo inlet configured now? (and the path from turbo to the intake?) Also, the intake ports need to be as straight of a shot to the head port/valve as can be made.
#64
It might have been doing it , but I don't really 100% remember ..
#65
#66
The manifold it half a Torker 2 with plenum mods
#67
I agree that a modified Wentzler tunnel ram would be very good improvement if you don't get another intake made.
Possibly a lot cheaper than a sheet metal intake. How big is the intercooler?
#68
http://www.treadstoneperformance.com...ers&f_start=20
#69
If im going to make a new one it will be sheet metal...the one I made took a really long time to make it work right..
#70
That's the photos I wanted, thank you for sharing, that was thinking outside the box!!
#71
With having no divider between the 2 ports how is the off boost drivability ? Does one steel from the other . Wouldn't it take the individual velocity away from them ? How is it just cursing a round?
#72
(especially for your 4 cylinder) The tuned length would be who knows with no runner basically? With your 4 cylinder the individual runners to the plenum may be more critical? (with a V8 the problem wouldn't be as bad?)
#73
I think you're right. Thanks for saying something because was considering maybe trying it..
#74
It just dawned on me that my elbow probably adds to my plenum size. So I guess I have to figure that in too. Maybe my plenum isn't the problem at all? Would I get a bouncy boost gage needle if I had a exhaust leak?
#75
Thanks Tom, yeah, I milled away the head port divider walls, not right down to the bolt boss (I milled them about 1.5" down as per your advice).there is now a lovely straight shot to the back of the valves from the intake plenum.
Charlie, the engine idles nicely and there doesn't seem to be any charge robbing (reading off the plugs), cruising is fine too, I was expecting it to be soggy down low but it's not bad at all. The carbs are Holley 600 double pumpers too, I would have liked 450's but couldn't get them. That is one cool 4 pot motor! |
#76
With a Modified Firing order I believe that you could have a firing order where there would be no robbing of the fuel from one common port (like the 5/7 cylinder firing order).
Tom V.
#77
I looked at your deal again Charlie and your 4 cylinder engine (with the cylinder head mounted on the passenger side of the vehicle is a NATURAL for the center divider removal modification. You would always be drawing air and fuel from either the front pair of runners or the rear pair of intake runners but never twice from the same runner pair.
I have attached a image of the Pontiac Firing order 9when using a stock camshaft firing order. Charlie's head is on the passenger bank (the 2-4-6-8 numbered bank). If we say the cylinders 6 & 8 are the "Upper Cylinders" and cylinders 2 & 4 are the "Lower Cylinders" we can go thru the Pontiac firing order. 1 - 8- 4 - 3 - 6 - 5 - 7 - 2 Starting off: 1 (is not used), 8 (is a Upper), 4 (is a Lower), 3 (is not used), 6 (is a Upper), 5 & 7 (are not used), 2 (is a Lower). So the pattern is Upper, Lower, Upper, Lower then it starts again Upper, Lower, Upper, Lower, .......... So you could remove the divider wall between the "Upper" Runners and the divider wall between the "Lower" Intake runners you will never have robbing of the Air/Fuel Mixture between the two cylinders next to each other. So you could do a TAFF mod without any issues. Understand?? Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 06-06-2016 at 06:49 PM. |
#78
Everything between throttle and runners is plenum area.
#79
Charlie, did you read the post above?
It looks like you could remove the dividing wall of the paired runners and not have an issue. Do to the unique 4 cylinder firing pulses. And yes, the plenum elbow is probably adding another 80-90% volume to your system. Tom V.
#80
It would be interesting to hear John M's views on the intake.
