efi
Anyone done efi swap that fits under the shaker
I'd say we're mostly carburetor dinosaurs here.......but you never know...
Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
I haven't yet but there are many companies that make throttle body EFI that are the same dimensions as your carb.
Fast, Edelbrock, MSD, Holley. So basically if your shaker fits now it will fit with their kits.
Black 1978 Trans Am SE Clone Butler Performance 474 E heads Built 400 Trans with 3000 stall 17" Y/O 1978 Y88 4 Speed T Top PHS Docs Restored 1987 Grand national 4.1 Stroker Motor Just a 6 Cylinder Buick |
I run a Holley projection that fits. Actually have a 1" spacer and an RPM intake too. Its all coming off this winter for a new multiport system.
1972 HO Trans Am auto White/white 1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue 1978 Trans am gold/ black ,T56, t tops, EFI 474, Build: http://www.pro-touring.com/showthrea...1978+g+machine 1999 30th Trans Am 6 spd, T top |
I would think a throttle body on a Torker II/EFI intake(Called the Victor EFI?) would fit and since TB are shorter than many carbs may need a spacer to get the Shaker up.
Victor EFI and Super victor will work. Super victor (single plane) needs the top to be milled down a bit though. Also depends on height of throttle body
Visit a local Pick A Part.
Chevy and GMC Pick PU's have these air cleaner spacers.
Its ok to giggle and snicker, Dont laugh and point |
I installed the powerjection III last year on my poncho.
Air cleaner spacers will work but adding plenum voulme is not a bad thing with a spacer under the TB either. Most factory EFIs have a decent sized plenum.
Have this setup with Shaker in factory position on Eldelbrock Performer manifold using spread-bore to Holley square-bore adapter w 1" spacer on Pontiac W72 400.
