Old 06-12-2019, 10:57 PM
gtorich gtorich is offline
Default Pitman arm
Was gonna change out my "what ever box" I have in this thing to find out what exactly it is.
Bad pics, but I assume the pitman arm should be up higher, not even sure I have the right pitman arm in there in the first place. Thought it was supposed to be curved on the p/s on a 66.
Any one know the size socket that fits that pitman nut......put a 1 5/16 12 point on it, seems a little loose...…...seen a video where the guy uses a 1 3/8 socket and impact driver on it, so that doesn't sound right.
Pics are bad, I got a little carried away years ago with the POR 15...…
Let me know what ya think.
Rich
Name:	Pitmn arm (3).jpg
ID:	514035   Click image for larger version
Name:	Pitmn arm (4).jpg
ID:	514036   Click image for larger version
Name:	Pitmn arm (1).jpg
Old 06-13-2019, 12:16 AM
64speed's Avatar
64speed 64speed is offline
I would use a 6 point socket. I will look Saturday when I get back from the beach and tell you what size it is if nobody answers before then. As far as how far on the arm goes I always use my good impact and as far as it presses it on is how tight I make it. Never hade one come off
Old 06-13-2019, 05:38 AM
Jeff Hamlin's Avatar
Thumbs up
That looks correct. It shouldn't bottom out.
The shaft has a slight taper, as you torque nut on to the 140 spec it's good to go.
Old 06-13-2019, 08:34 AM
Hey Jeff, thanks for that pic, otherwise I would have been trying to get that nut up higher.
Now to get a new rag joint , hopefully that doesn't turn into major drama as with everything lately with this car. lol
Rich
Old 06-21-2019, 12:36 AM
64speed's Avatar
Your pitman arm is as high up as mine so I think you’re good to go
