timing question. can it change when the car is hot causing restart problem
After short drive car will not start (400 engine, tripower setup)normal temp 175.
Car seemed to burp thru center carb while trying to start. New battery, plenty of crank. MSD ignition rebuilt weights and springs. |
Engine doesn't crank or cranks and won't start?
If your asking if the timing changes when the engine is hot the answer is no. Hot start problems can be caused by running too much initial timing. What initial timing are you using? Other issues may be causing your problem. A worn starter or insufficient engine grounds Can be the problem. Years ago I used a reproduction battery and it didn’t have enough CCA for a good hot restart. I replaced the battery and things were fine until the starter started to wear. . I replaced the starter and it cranked fast at any temperature.
http://ultimategto.com/rest05cars1.htm |
True. The faults that you can get away with on a cold start can leave you sitting with a hot engine. Just baking the old big starter can sometimes be enough with everything else in fair shape. Add in a questionable battery, smaller cables, corroded terminals, or a little too much initial timing and you will be camped out for awhile.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
I had a hot start issue being caused by my advance weights sticking inside the distributor. Turned out they had some light rust on them and the springs wouldn't retract them to initial timing. Chased my tail on that one blaming it on the carb. Easy fix.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Jeff |
Finally got back to the car. My initial timing is 7, just checked. Ran engine, warmed to normal temp then tried to restart. Starter motor turned over slowly. Labored very hard.. battery is new and had full charge. I am looking at changing out the starter. I do run headers. What is a good replacement
Thanks in advance Dan |
VERY low initial timing there. No headers here but my Powermaster w heat shield has served me well for 12 yrs/35k miles
I had to put new weights and springs because of light rust buildup.
Which powermaster are you using
I have a good sampling of IMI, Summit, and Power Master mini starters on my vehicles and they have all performed very well and lived a long life. The IMI is still working great that I purchased in the mid 90's when my stock hi-torque starter gave up in the staging lanes and cut my day short.
Good point that sticking weights would keep the timing advanced and really increase the load on any starter.
Dan, not sure which Powermaster but it cost $200 12 yrs ago. It worked great on my 400 w 12/13 initial degrees and works fine on my 467 w timing locked out at 37 degrees (constantly 37, w no advance at all). Hopefully the weights and springs helped to return timing back to initial, most agree heavy stock springs and weights work best.
Update; Put in a summit mini starter, wrapped with heat shield, replaced the timing chain and sprockets, found a loose ground wire, removed the rev limiter chip from the MSD unit, set the timing at 13 and now it starts and runs great. Lots of little problems contributed toward hard restarts. It now starts easily and the engine runs strong.
Thread Tools | |
Display Modes | |
