Tri-Power Tech 57-66 Tri-Power Talk
Old 03-22-2019, 07:49 AM
Carmine Carmine is offline
Default 1965 tripower
Hi everyone. Couldn't find an answer to this, so I'm asking here. Will a '65 tripower fit a '66 and later engine??? If so, how much later?? Is there much difference, if any, between the '65 and '66 tripowers?? Thank you, Carmine.
Old 03-22-2019, 09:02 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Yes, My 65 Tripower setup is ALL correct for 65. My block is a 66 389.
Dave
Old 03-22-2019, 09:05 AM
dhcarguy's Avatar
Dave
Sorry, forgot to mention that the center carb on the 66 tripower is the larger base.
Also go to Mike's tripower to get tons of info.
Also Dick Boneske on this site is also a wealth of info.
Old 03-22-2019, 09:27 AM
TROYBOYONE's Avatar
TROYBOYONE TROYBOYONE is offline
I have '65 carbs and intake sitting on '68 #16 heads, which sit on a '70 400 block.
Old 03-22-2019, 09:31 AM
It will fit all the way up to the EGR years.
Old 03-22-2019, 12:33 PM
Dick Boneske's Avatar
The '65 Tripower will fit all Pontiac engines from 1965 through 1979 except for the 301/265 versions.
The later cylinder heads, however, sometime in the '70's, have a larger passage for the heat riser passage. There are gaskets available to cover the hole and makes the '65/'66 Tripower swap a breeze.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-22-2019, 01:31 PM
Yes, it well fit to '79 but I saw no need to get into the BS details. I had one on one of my '77 GP SJ's way back when. However, there was more to it than just gaskets. I did not mention the 301 because.... well.... who considers a 301 a Pontiac engine? Not me.
Old 03-22-2019, 04:09 PM
OK guys. My question was answered about fit. Isn't the top center carb, on the '65 tripower, smaller then the one on the '66?? Does this affect anything or even matter?? Would the cfm be the same of both?? Thank you, Carmine.
Old 03-22-2019, 04:45 PM
Not just the top, the whole carb, therefore CFM is different along with everything else.
Old 03-22-2019, 06:39 PM
tom s tom s is offline
Chief,you have never built a HiPo 301 block.Tom
Old 03-22-2019, 06:59 PM
OK. Last question. I promise. Is there anything wrong with putting a tripower center carb. from a '66 onto a '65 intake?? Thank you, Carmine.
Old 03-22-2019, 07:14 PM
wbnapier wbnapier is offline
Although the 1966 center carb has a larger throttle-bore, 1-11/16", compared to '64 and '65 carbs with a 1-7/16' throttle-bore, the venturi size is smaller on '66.
Center carbs of 1964 and 1965 Tri-powers have 1-1/4" venturi, whereas the 1966 center carb has a 1-3/16" venturi.
I think this means the '66 will flow less CFM. Someone can chime in and correct me if I am wrong on any of the above.
Edit - For more info, read #8 here: http://www.pontiactripower.com/faq
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 03-22-2019, 07:40 PM
OK. Thank you very much, Carmine.
I just tried that link. "Page not found".
Old 03-22-2019, 07:57 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Carmine, the link worked for me.
"Bill"!
Old 03-22-2019, 08:38 PM
I will build one of those when I am ready to build an HT4100, Northstar or odd-fire V6. There is more but I am sure you get my point.
Old 03-22-2019, 08:42 PM
Perhaps someone can post up a bare '65 and a bare '66 intake. You can clearly see the difference. Had I had read this earlier I would have snapped some but now it will have to wait until this time tomorrow.
Old 03-22-2019, 09:05 PM
I really dont get your point except because you have not built one you dont know what one is capable of,that all.Tom
Old 03-22-2019, 09:39 PM
So what you are saying is that you do not know what GM engines to stay away from. I was around when the 301 was out. Like the Cadillac HT4100, as soon as word got out what a POS these engines were, Pontiac dealers could not give them away and did not want them. The very popular T/A died on dealer's lots if they had a 301. And like Caddy dealers when a customer wanted to trade in a Caddy with a Northstar, Pontiac dealers cringed when a customer came in with a 301 car. I remember dealers calling them 50,000 mile cars, because you were lucky to get that out of them. Yes, there were a few (very few) exceptions like a guy I know with a 95,000 mile Grand Am or another guy that got 126,000 out of his 301 but its pretty sad when you have to think hard as to a 301 getting over 50,000.
That is why any Pontiac guy around here doesn't consider a 301 when talking Pontiac engine history. I liken it to a bastard child with its Papier-mâché crank.
Old 03-22-2019, 09:57 PM
Tom's 301 stroker build:https://forums.maxperformanceinc.com...d.php?t=710524
Tri-Power intake ID thread we've all seen before, you're not going to find much better pictures to see the difference between the two most popular ones ('65 & '66):https://forums.maxperformanceinc.com...d.php?t=786314
Old 03-22-2019, 10:24 PM
Well, I'm sure when someone says you can't or shouldn't, someone will. I was the same way when I started racing GM overdrives 20+ years ago. I still do not consider a 301 a Pontiac and would trust an Olds diesel first.
