Upgraded rear brake pads?
I posted this over at YB, but curious if anyone has experience using the high dollar brake pads. I always used them for circle track, which of course is a little different than how my 68 is used. Here is thr current situation...
Ford 9" with Explorer rear disc brakes in my 68 firebird. Manual MC with 4wheel disc distribution block. My braking generally seems ok with plenty of time to slow down after a drag run, but I feel like I could use more rear brake. I see that the generic semi metallic pads are only 1" wide, while the surface area of the rotor is 1.75" wide. Couple questions... -- does anyone know if a wider pad is available for the Explorer calipers? -- would a Hawk Ferro-Carbon pad (or other) provide more cold friction stopping power than a generic SM pad? Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
Interested to know this too because the brake pads that came with the Yukon kit I got for the 9 inch with explorer brakes seem chintzy. Tom Vaught has this setup maybe ask him
I've used the Hawk HPS pads on several different vehicles, and love them. On a Tacoma and an FJ Cruiser, the pedal "feel" improved dramatically over the OEM pads. Dusting is minimal.
I tried the "improved" HPS 5.0 pads once, I believe they are supposed to designed for ABS systems. Did not feel any better than the regular HPS, and caused a reddish-brown dusting.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
I did put a set of Hawk ferro carbon "street" pads on the rear last week, but really cannot tell any difference... the front already had the Hawk ceramic pads, which came with the aerospace disc brake kit.
Thread Tools | |
Display Modes | |
