Old 06-29-2019, 12:26 AM
goatman73 goatman73 is offline
Default radio question
my 70 judge had the am/fm stereo option,was wondering if this would be the am/fm multiplex unit or just am/fm stereo?
Old 07-08-2019, 02:34 PM
The A body 1970 stereo transitioned from a 2pce to a one piece during the model run.
Here is a pic of the bracket your car would have if it was built with the 2 pce stereo. This is looking through the glove box opening towards the right front fender.
This pic is of a 69 LeMans with a reverb amp but the bracket and the amp housing are identical for the stereo multiplex. If you don't see a bracket you can still look to see if the two screw holes are there on the back of the plenum (the two screws in the pic)
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 07-08-2019, 09:53 PM
i took a look and it does have the two holes so guess that means had multiplex unit,guess will have to search for one, thanks for the info.
Old 07-08-2019, 11:13 PM
It’s much easier and cheaper to find a one piece stereo and once installed you can’t tell. There are a few from time to time on eBay.
1969 Bonnie Cvt
Old 07-08-2019, 11:15 PM
If your car ever goes out in the rain you’ll want to seal up those holes. The plenum is under high pressure at speed so water will get in to the dash insulation and down to the carpet. The factory used sealer on its those screws.
1969 Bonnie Cvt
