Old 08-09-2019, 07:00 PM
Tanksta's Avatar
Tanksta Tanksta is offline
Default Decoding frame
I have this frame, bought it as a 66 GTO frame. The only #s I have found so far are on the rear where the photo is circled. Stamped 7K606747.
Any ideas? Could it be a 67 made in KC?
ID:	517368   Click image for larger version
ID:	517369   Click image for larger version
1967 Lemans Convertible_____Tanksta's facebook page______
Old 08-09-2019, 07:59 PM
Old Goat 67's Avatar
My 67 KC car was stamped there with 7K143XXX.
Old 08-09-2019, 08:08 PM
Tanksta's Avatar
I was thinking it may be a 67 KC frame
Old 08-10-2019, 05:24 AM
Geoff Geoff is offline
The 66 frame has the large opening [ about 5" ] to engage the top of the rear springs. 67 & later had the smaller opening to take a pigtail end.
Pretty hard to be definite from the pic, but does look like the larger 66 opening.
Old 08-10-2019, 05:59 AM
I'd guess 67.
Here's mine.
Here's his.
Old 08-10-2019, 06:17 AM
Jeff Hamlin's Avatar
Exclamation Definitely '67
Here is a shot of the larger '66 spring pocket noted above,
Also showing the correct spring insulator for said pocket.
FWIW all you'll need is the '67 Rear Springs and that frame will work fine.
Old 08-10-2019, 11:12 AM
Tanksta's Avatar
I'd guess 67.
Here's mine.
Here's his.
Yessir looks identical to yours.
