Evac pump pulls excessive amount of oil
I pulled a quart of oil through the evac pump during a recent autocross in just two runs. See picture for my set up.
I have a 3/4" spacer under the factory covers for total of 3 1/2". The bottom of the Moroso breather is 3" from the rails. I can switch to a 3 3/4" cover and move the pick up point higher. Do you guys think this will solve the problem? I didn't realize how much oil pools in the heads under high RPM. 455 w/ 4.25 stroke / .060 overbore Kauffman heads |
Sorry I don't have an answer, but that engine and engine bay look absolutely beautiful. Super, super clean.
How much vacuum do you have it pulling at peak rpm?
Usually 10-12 inches is all you need. Do you have an adjustable valve on the pump? I can't tell in the picture. |
Thanks. It didn't look to good after blowing oil out of the catch can breather all over the firewall and headers!
According to GZ, it pulls 19"-22" at 3500 rpm. I don't think it's adjustable, but would it make a difference if oil is pooling at or just below the breather? |
You can purchase a separate restrictor to adjust the vacuum. https://www.gzmotorsports.com/relief-valves.html I don't know that it is the oil "pooling" in the cover as much as there is a bunch of oil splashing around and therefore mist. I can't offer any suggestions beyond that, as I am struggling with the same thing (only a quarter mile at a time). I continue to play around with added baffling, gortex filter media and dropping the total vacuum at high RPM. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Make a thin sheet metal perforated Baffle that is 1/2" tall and epoxy it under the breather.
This is what I have done at times, also you might make a restrictor that goes in the pumps suction line.
You're going to need a regulator to turn that down. They mount on the pump where your hose connection goes to the valve cover. What ever your peak rpm is you want maybe 10-12 inches max at that rpm, and the rest will take care of itself. Once adjusted, usually light throttle cruise will see 3-4 inches of vacuum. Once set like this it'll go 200-300 miles before you'll have to drain the small catch can that holds about 8-10 ounces in our case. On a side note, pulling as much vacuum as you're pulling is said to pull oil away from critical areas like wrist pins and can cause failure. However you want it pulling some oil, that's how the pump lubricates itself. If you aren't pulling at least a few ounces after a couple hundred miles, then according to instructions you have to add oil to the pump on a regular basis, which is a pain in the butt by the way, lol. |
I'll reduce the vacuum before I relocate the pick up point or consider restricted push rods. It's certainly the easiest, most cost effective solution.
I convinced myself there was a big pool of oil in there. I never imagined 60 seconds or so of high RPM could pull that much oil mist. Glad I asked, and thanks for the suggestions. |
Are you running a dipstick?
1969 LeMans..Liberty Blue 2001 WS6..Sunset Orange 1973 Pro Street Firebird..Lucerne Blue |
Yes. I'm running a dipstick.
That's part of your problem. The motor needs to be sealed
Pull dip stick tube and put a vacuum cap on it. You need the regulator to lower the vacuum. You have to much.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Just curious what oil pump are you using?
60 lb oil pump w/ a shim.
I'll cap the dipstick tube and test for air leaks. |
The one here has a dipstick and it works perfectly fine.
I would guess if you have a dipstick that the seal for the stick is non existent then it could be an issue. |
Check where the tube gets pressed into the block. Mine was leaking there and by the valley pan.You do not need a lot of air pressure when checking. 10psi max.
Wouldn't a dipstick be a leak point and cause lower vacuum, not too much?
The leak point at the dipstick actually will make the pump pull harder to compensate for the vacuum leak which can result in excessive oil being put into the catch can.
I am reading to learn I don't really think I need this . The one question I have is , sorry if this is a stupid one, why can't you just return it to the oil pan like they do with turbos?
Let's make welfare as hard to get as Veterans benefits! |
Thread Tools | |
Display Modes | |
