Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
WTB - Modified dual snorkel air cleaner
I know this probably a longshot but does anyone have a modified dual snorkel air cleaner assembly that is modified to sit on a Holley carb? Or does anyone know how to easily modify it? My buddy has a 70 lemans he would like to put it on, instead of a regular parts store 14" bull crap one. Would be good if it was all black, no chrome lid, he hates chrome. I just figured I'd post this before we butcher up a re-pop one.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
I too would love one for a 1050 Dom fit.
I ran a Holley 3310 with a original GTO duel snorkel in High School.
How does it need to be modified to fit a Holley?
Are you doing a 4150 or 4500? I built a dual snorkel for my 4150 quickfuel. I just modified my 76 Air cleaner assembly. I also found myself some of the cylindrical cone air cleaner. I like the looks of the 455 ho air cleaner.
Where did you find the air filter? Been looking for a cone style for the TA.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
Check this thread. https://forums.maxperformanceinc.com...ght=Wfo+airaid Been so long ago.
https://www.airaid.com/concept I would have to measure mine or find part numbers. I just took my lid and cut it for the top. Sit nicely inside the shaker. I do have the bigger one, but not gonna use if your interested.
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 01-19-2022 at 12:38 PM. |
The part number on the one I bought that I'm using is 801-452 and the spare one that I have that I would sell is 801-456.
I built one and will sell it to you. It has a aftermarket drop base and will fit a holley.
Jeff Ianitello |
PM sent.
I'd think a used one could be had cheaper than a repop. I know the service replacement 71-72 'Ram Air' air cleaners clear a holley - but never tried fitting any other factory air cleaner on top of a Holley.
Do the ram air cleaners have dual snorkels?
they are designed to seal up to the hood with rubber boots.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
The Following User Says Thank You to Holeshot71 For This Useful Post: | ||
Man, I'm learning alot in this thread! So if we cant get a used one and he orders a repop he should order one for a 70-72 GTO/Lemans?
Can’t say whether or not the Repop will fit, never used one. I can only speak from my experience with the 70 to 72 GTO dual snorkel. The Firebird 400 dual snorkels of the same years have a drop base that may not work. Those are easy to identify, they have a indentation in the back of the base to clear the distributor. Check out the picture for reference.
Correct, the factory 2nd Gen bases (both T/A & Formula) are 1 1/2" drop & the center area will not clear the bowls on a center hung Holley. Have restored several early 2nd Gen T/A & Formula bases that previous owners hacked on to clear the center hung bowls of their Holley. On a '70 Pontiac A-body my suggestion would be to buy the PartsPlace dual snorkle 70-72 GTO repo. Nice clean originals tend to run more $$$.
Thread Tools | |
Display Modes | |
