1996 bonniville blowing out fuel
i have a 96 bonniville that is blowing out raw fuel out the exhaust anyone
happen to know what the problem may be? |
Didn't they have a problem with the fuel pressure regulators?
i am not sure but i will look in to it thanks
Raw fuel out the exhaust? how is it running otherwise? It could be the Fuel Reg is bad letting to much fuel, but more likely it is a misfire of one of the spark plugs, or a partually clogged fuel injector. But we will need more info to help, Check engine light on? Any codes being sent out? (if you have access to a code reader, if not most auto parts stores will read the codes for you.) How many Miles? Did you work on anything shortly before the problem started? I myself have been guilty of creating one problem wile fixing anouther.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
well heres the thing i just talked to my uncle the one i got it from and ther is no check engine light on he said he cleaned the front four injectors so it could be a rear but before all this happened he changed the plugs and wires then after it started doing this e put a new fuel pressure regulator on it and and egr valve i dont have the car with me at this moment but will have it in my possion after christmas
Raw fuel out the tailpipe??? Our you sure its not condensation. I don't think raw fuel is going to make it past a cat. Front 4 inj ? you mean front 3. 3.8L engine. How does the car run?
