Does anyone know where the heater/AC blower relay is on a 93 Bonneville SSE?
My blower is running on high speed even with the car off. It is not one of the relays on the firewall relay center as I have pulled all of them and the blower still runs. When I pull the firewall AC fuse it will stop. Thanks,
Rick |
Hi,
I've had to replace mine a couple years ago, it is called the blower control module and it is not a relay, it is solid state, it is mounted on the blower housing. I will have to check my factory service manual to be sure but I think I had to remove the maxi-fuse center to get at it. It is right underneath the maxi-fuse center. It actually sits in the blower chamber so the blower air keeps it cool. Let me know if you need more details |
Thanks. I've been in that area before to clean the crud off the AC evaporator (or condenser?). I remember having to go through that fuse panel. Any more info would be appreciated!
Thanks,
Rick |
FYI did my 94 today. Got it out of a junk yard. Same problem. You have to take the underhood fuse block assembly off and it is under that. Two pluga and 4 7mm screws. Junk yard part was 10.00 bucks. NADA was $175.00 easy fix. 30 miuItes.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads Boss Bird Funny Car Best pass to date 08/06/2016 6.027@231.64 Allpontiac Big Chief Aluminum Engine Block http://www.AllPontiac.com |
