master cylinder
What's a good master cylinder for disc /disc no booster
how455 |
More detail about the car please?
MCA390320 If I recall the lines are reversed: my original master cylinder front port went to the front brakes and this was opposite. |
Some of the choices will be affected by caliper piston size, pedal ratio and how you like brakes to "feel". Bigger pistons need more fluid to move them so a bigger piston but that increases foot pressure to get the same line pressure.
15/16-1&1/8' seem to be common for most folks, or the equivalent metric piston sizes. Too small and there is move pedal travel to move the same volume. I have roughly a 15/16" on my Wilwood Dynalite front/D154 rear caliper setup on the 79 Camaro/IA car. Started with a 1 &1/16 but the pedal effort the firewall was flexing some. Strange has a couple of Mopar style both larger than 1" but you can cross reference different Mopars (minivans etc)in different sizes-what i did. bolt spacing slightly different than GM but a die grinder makes them work
