Old 04-24-2021, 07:10 PM
steves1967 steves1967 is offline
Default Disk/ Drum master Cylinder help
I installed the Wilwood 4-piston disk brake kit on the front of my 67. The rear has a drum brake setup. What master cylinder should i be using? The old Strange Engineering catalog used to have a chart in it for with M/C to use- but no more.
Thanks,
Steve
Old 05-01-2021, 08:05 AM
1968firebird455 1968firebird455 is offline
Send a message via AIM to 1968firebird455
Manual brakes use a 1" bore. Power brakes use a 1 1/8" bore. Use an adjustable prop valve and you should be good to go.
Redline Design
