Old 08-21-2019, 08:42 AM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Default Chrome!
The chrome is amazing on the car, all original I assume. My 66 chrome has not held up as well. How is the chrome on vent windows? Mine is a Fremont car lived most of its life in bay area, but still some pitting on vent windows. The worn keys are awesome given the story, keep the pics coming
  #42
Old 08-21-2019, 09:13 AM
GTOnly70's Avatar
GTOnly70 GTOnly70 is offline
Awesome car. Nothing beats a true survivor!
  #43
Old 08-21-2019, 02:55 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
All of the chrome appears to be original and it is pretty nice. There is some pitting on the lower areas of the bumpers, but not bad. As for the vent window chrome, they are both pretty bad where the inner areas meet the weatherstrips. The weatherstrips are hard and brittle as well, but not bad enough to change them.
  #44
Old 08-21-2019, 11:34 PM
I've had fair results with WD-40 on softening hard rubber if it's not too far gone.
That car is looking absolutely fantastic after the cleanup. Looks like the Americans have the spokes painted body color?
Old 08-22-2019, 12:20 AM
428ho4spd's Avatar
Thank you for the tip, I'll give that a try.
Thanks, I'm having fun cleaning it up! They're a lighter color gold, but they do look good on the car. They too need a good cleaning and polishing.
  #46
Old 08-22-2019, 06:59 PM
Jeff Hamlin's Avatar
Thumbs up
Great results with Meguiras 40
  #47
Old 08-23-2019, 12:48 AM
428ho4spd's Avatar
#40 is great stuff! I've been using that for years on my interiors, but never even thought about using it on weatherstips. Thanks for that, I'll try it when I start on the interior.
  #48
Old 08-23-2019, 03:38 AM
The 303 vinyl and rubber protectant is also very good although I've never tried it for restoring aged, brittle rubber
Old 08-29-2019, 06:17 PM
geeteeohguy's Avatar
Your car is looking absolutely amazing. Nice work! Good to see a classic go to 'the right guy'.
Jeff
  #50
Old 08-29-2019, 08:11 PM
428ho4spd's Avatar
Default Some new outside photos today.
Thanks again for the compliments, its coming along nicely. Today I worked on the dash mostly, removed that old yellow upper dash insulation that was crumbling all over the place and then removed the old Sun tach to reinstall the "dummy" plate. Cleaning/conditioning the seats and door panels with Meguiar's #40 is next on the list.
ID:	518947   Click image for larger version
ID:	518948   Click image for larger version
ID:	518951   Click image for larger version
ID:	518952   Click image for larger version
  #51
Old 08-29-2019, 08:14 PM
428ho4spd's Avatar
Default Interior from today.
Looks much better without that tach sticking out of the far right pod.
ID:	518954   Click image for larger version
ID:	518955   Click image for larger version
ID:	518956   Click image for larger version
ID:	518957   Click image for larger version
  #52
Old 08-29-2019, 09:35 PM
400 4spd.'s Avatar
I love it!
  #53
Old 08-30-2019, 01:10 AM
OZZIEVILLE 67 2 door's Avatar
OZZIEVILLE 67 2 door OZZIEVILLE 67 2 door is offline
Thanks for great story and pictures
Sent from my SM-T585 using Tapatalk
Old 08-30-2019, 02:54 AM
Incredible!
Old 09-01-2019, 09:06 PM
428ho4spd's Avatar
Default Soft Trim Broadcast Sheet
I found this lying on the floor under the back seat the other day. I can decipher some of it. Anyone know what the two-letter codes in boxes 78 - 87 are in reference to?
  #56
Old 09-08-2019, 07:15 AM
1967SC's Avatar
1967SC 1967SC is offline
Best thread here in years.
Keep the pictures coming,and good luck !
1967 GTO Sport Coupe
49,xxx orig.miles
Champagne/Parchment
30 Original Owner Ordered PHS Documented Factory Options
Second Owner
  #57
Old 09-08-2019, 12:13 PM
428ho4spd's Avatar
Looks like I may be able to save the original paint on the wheels that were sprayed over with black paint by the original owner. My friend suggested trying lacquer thinner and it worked quite well. I carefully removed a layer at a time and it all wiped off. I then used a paint cleaner and wax over that. They wont be perfect, but at least will remain original paint this way. Also cleaned up one of the worst caps, that came out nice too.
ID:	519703   Click image for larger version
  #58
Old 09-08-2019, 11:06 PM
MUSLCAH MUSLCAH is offline
^^^^^^^^^ are those wheel covers ....called deluxe wheel covers by the PHS folks ?
  #59
Old 09-08-2019, 11:36 PM
242177P's Avatar
242177P 242177P is offline
Default From Eric White's book
  #60
Old 09-09-2019, 08:54 AM
^^^^^^^^ thanks for that....ill have to look at my PHS and see if mine were deluxe or custom delux
