Old 08-06-2023, 11:11 AM
lucky1 lucky1 is offline
Default SSBC rear disc brake calipers. Replacement 65 GTO
I have SSBC rear disc brakes on my 65 GTO.
The E brake part of it doesn’t work worth a damn!!
I learned they are ford thunderbird based, lol
Can anyone recommend a caliper that would be a direct replacement with an
Effective E brake ?
Trying to avoid another “Kit”. If that is possible. It’s a 4 sp trans.
Thank you.
Old 08-06-2023, 11:39 AM
How thick is the rotor?
Old 08-06-2023, 01:13 PM
Default Rotor
Don’t know , have to measure it.
Kit was installed 5 or 6 yers ago and I don’t recall specifics
I’ll let you know. 👍
Old 08-06-2023, 01:28 PM
Takes this pad if that helps.
Old 08-06-2023, 01:41 PM
[ATTACH]Click image for larger version
Old 08-06-2023, 01:51 PM
Pad does not help - Ford used that pad on several calipers with different thickness rotors, so different caliper frames.
You will need to measure here.
Old 08-06-2023, 10:51 PM
Default Rotor thickness
Old 08-06-2023, 11:29 PM
A cursory search shows nothing of the usual suspects running a 1/2" thick rotor.
Best bet is to have B&W Brake in KCMO rebuild them for you.
Once this is done, every time before you shut off the car, engage the parking brake.
This will keep it in form.
Old 08-06-2023, 11:41 PM
Can you explain what “keep it in form”
Means ?
Old 08-07-2023, 12:18 AM
They need to be used regularly or they freeze up.
Old 08-07-2023, 08:10 AM
grivera's Avatar
grivera grivera is offline
The 69 Lemans I recently acquired has SSBC rear brakes and I called the company directly- Tim was great at answering questions- maybe call them for the specs on your rotors.
(716) 775-6700
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
