Old 06-03-2019, 10:59 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default Those With Luhn Superchargers, What Do You Think?
I'm interested in going to forced Induction on my GTO. I am already running the Holley HP on E40 and am not sure if getting a single custom turbo setup made is worth it vs just doing the Luhn supercharger. I'm 100% street and just need a bump to get the big guy moving around town. I'm not doing an intercooler and don't have the AC in the car so it's a little more straight forwards.
I'm not sure how I'm going to get a down pipe past my passenger firewall with my fuel lines and current brake vacuum canister so I'm leaning towards a Supercharger.
Any issues after getting some miles on it?
Install time needed?
Real cost of the complete kit?
Anything else you'd add in please do.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 06-03-2019, 11:52 PM
GTOGEORGE's Avatar
ANY forced induction set up will cost MONEY when starting from scratch (if done correctly). Buying used would be cheaper, there is more money involved with a boosted set up other then the supercharger and pulleys....although its probably easier and less expensive the a turbo setup.
GTO George
Old 06-04-2019, 09:03 AM
Talk to Richard Guido (from Canada) about the Luhn Supercharger system on the street.
He ran one on his 65 GTO for several years. He could give you a lot of good advice.
I would give you one piece of advice, Buy a C&S Boost Carb from Roger (thru Luhn).
It will be very close in the tune-up for a street car right out of the box.
Old 06-04-2019, 11:07 AM
You could install a Vortech Supercharger system or a Procharger system on a Engine in a weekend. To do a Turbocharger system could be a much longer process.
A Lot of the Parts for the Pontiac system are also the same parts for a Chevrolet system or a Ford System, (Aeromotive Fuel Pump, Tanks, Inc Tank, Holley Carb, Fuel Pressure Regulator, By-pass Valve, etc.
Mark at Luhn performance does a great job on the Pontiac Brackets, and putting all of the parts together as a system. Richard Guido mentioned in a previous post has a lot of experience working with Mark. Centrifugal systems typically can make up to 1000 hp for a reasonable cost. Far more HP than you need on the street.
Mark's 865 HP 455 engine was a very basic engine set-up. It made that 863 hp at only 5300 rpm too. A YSi supercharger could have easily made over 1000 hp. But you don't need 1000 hp on the street.
Old 06-13-2019, 01:42 PM
bad69bird's Avatar
bad69bird bad69bird is offline
I used Luhn's supercharger kit for over 10 years with good success. I am not sure on the cost nowadays, but his stuff is well engineered. I would let him spec everything out and buy it from him.
Price wise it will depend on what you want. Prices depend on if you get it used or brand new.
Carb: $1200-2k
Fuel pump: $300-$750
Regulator w/fittings: $200-$300
Blower: $2500-5k
Luhn's brackets: I don't know. He will probably sell the brackets/ blower together.
BOV's: $250-$400
Lines/fittings: $500-1k
Hat: $400-$500
Incidental chit I can't think of that will come up: 1k-$3k.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 06-13-2019, 02:00 PM
GOAT8U2's Avatar
Thanks for all the comments everyone, luckily I already have the Holley HP with 80 pound injectors running E40, Magnafuel pump, -10 lines and Fuelab boost referenced regulator.
Mark sells a complete kit with the blow off and hat for around $7500 so I guess I'm looking at an install, tune and I should be good to go.
I was mainly concerned with how the engines and the kit was holding up over time but after reading other threads it sounds like just the superchargers themselves are the big longevity concern As long as the power isn't through the roof on the stock block.
I'm only looking for about 8PSI and nothing more than around 700 pounds of torque at the rear wheel so this should be pretty practical and safe with a good tune.
Old 06-13-2019, 05:17 PM
Years ago Luhn did a simple dyno test with a "T-Trim Supercharger running at 13 psi of boost. He made 863 hp at 5300 rpm and the torque number was even higher at 4800 rpm. Not sure he can make 700 lbs/ft of torque at 8 psi but 8 psi or 13 psi at 5300 rpm you are going to have a bunch of torque with a real street type supercharger.
Luhn has a long history (as bad69bird) posted when it comes to centrifugal superchargers.
Old 06-19-2019, 07:17 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What would 13lbs of turbo boost produce in terms of hp for the same combo?
Old 06-19-2019, 08:04 PM
Over 900 HP. The T-Trim Supercharger (accordijng to Vortech's Supercharger Dyno Stand, Engines take about 1 horsepowert for every 10 hp produced.
See image of Vortech 1200 HP Testing on the Test Stand.
So 863 HP rounded off is about 85 horsepower to drive the supercharger.
With a turbo and the same boost (inter-cooled like the posted dyno numbers from before) would make about 950 HP at 13 psi of boost pressure. Luhn has the ability to make 1000 HP kits all day long with a Pontiac Engine.
He has designs for Turbo Manifolds and he already has the Holley EFI stuff figured out.
Name:	Vortech Supercharger Test Stand.jpg
