Old 08-29-2019, 10:05 PM
tjs72lemans tjs72lemans is offline
Default Auto shift cable
Is there a reason an auto shift cable seems to buckle or bend? The old one I got with the car had a bend in the end. I got a new one and it seems to buckle when trying to shift into park. The tranny has been rebuilt and I can shift under car by hand with the reverse lockout hooked up ok and shift cable unhooked.
Old 08-30-2019, 08:27 PM
I straightened my old one with a bend in the end. It was a bit restrictive in the movement of the rod into the sleeve. I sanded the rod a bit and the restriction from the slight bend went away. I reinstalled in car and it functions without problems. Makes me think the newer ones are made of less quality material even though they look the same.
Old 09-01-2019, 11:15 AM
eric65's Avatar
eric65 eric65 is offline
my original came loose at the crimp down on the shifter so it was toast
bought a repo and it lasted a few time and came loose down on the crimp TOAST
looking for something else as well
Old 09-01-2019, 11:48 AM
1969GiPper 1969GiPper is online now
You may want to check your engine grounds to the body and frame. When those grounds are missing or dirty the shifter cable can end up acting as a ground. When this happens the cable gets hot and the plastic crimp gets hot and breaks. New cable will do the same thing unless you correct the ground problem.
