Door switch
On my 70 GTO the drivers door switch has a white and black wire running to it. I assume the blk wire is ground and the white is positive that turns on the interior light when the circuit is complete. However on the passenger door. There is only a switch without any wires running to it. Should there be a single white or both wires attached to the switch? Thanks
Pretty sure it completes the ground, and it's a 'complex' circuit where it has multiple point that can go ground.
Take a look at the schematic in the service manual. .
Per HWYSTR455, there are two functions on the driver side switch, only one on the passenger side.
You need a white wire on the passenger side switch. The black wire on the driver side switch grounds the key buzzer. Either white wire will ground the dome light. I'm sorry but don't know exactly where to tell you to look for your missing white wire... you might try removing the kick panel and looking for it.. hopefully just not routed where you want it. If you don't see the wire, removing the glove box liner to look for it might be easier than crawling under the dash. |
And just to comment, the jam switches I believe all have 2 terminals, doesn't maker which you use.
Maybe Held for Ransom will chime in, believe he has a good understanding, and possibly a suggestion. .
two prong:
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
I was thinking about the repops, but not often I actually look at them.
Thanks for the GM part numbers! .
Thanks all for the information. I guess I can jump a white wire from the DS to the PS, without adding another ground?
Hello
here is an original pair of 69's and the way they are hooked up
on the 69 Lemans Im parting right now Scott ours are 2/3rds the length as the one pictured above ... |
Please measure the total length of your switches. The new ones are fully extended, and the first time you shut the door, it adjusts the switch for that particular door jamb.
