Old 09-18-2019, 06:01 PM
Old Goat Racer's Avatar
Default Steering wheel. Paint dye ?
I want this wheel to be black. Tried rattle can but it flaked off .
Look'in for options ?
Everybody knows somthin.
Nobody knows everything !
Old 09-18-2019, 06:16 PM
Stuart's Avatar
Stuart Stuart is offline
Is it vinyl or leather? SEM vinyl dye is supposed to pretty good, for leather try Leatherique.
Old 09-18-2019, 07:08 PM
Came off a 78 Grand Am. I can't tell
Old 09-18-2019, 07:27 PM
Is it kind of a foam rubber material? I don't believe there is anything you can do but whatever you do it must be put on very thin.
Old 09-18-2019, 07:31 PM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
Use Sem. Wheel must be cleaned and all coating must be taken off, Use they perp and then use their adhesion promoter . I you don't prep right it will peel,
Old 09-18-2019, 07:37 PM
My TA wheel was baby blue; proper prep and SEM made it black - still very pliable and colorfast.
Old 09-18-2019, 07:42 PM
After going through this whole thing, I can note two things:
1) only real leather can be dyed, all others are really just a (proprietary) paint
2) preparation is everything.
I don't know about the material on your wheel, but if it's a molded, skinned foam then I'm not sure if that is an acceptable substrate. That being said, the SEM is a great product for its intended use.
Old 09-18-2019, 08:11 PM
Pretty sure it's not foam. Going to check at walmart for SEM
Old 09-18-2019, 08:42 PM
The Champ's Avatar
I doubt Wally World will have SEM.
Amazon is your friend.
Old 09-18-2019, 09:21 PM
Stuart's Avatar
Auto body supply houses or good local auto parts stores will carry SEM products.
Old 09-19-2019, 09:33 AM
I've seen many times where once you try to spray/dye them, they start sweating and getting sticky.
It's kind of a crap-shoot when you try to change the color. Better off getting one that's the color you want.
Old 09-19-2019, 09:51 AM
All the Car Quest stores around here sell automotive paint products including SEM.
Old 09-19-2019, 09:53 AM
I never experienced the "sticky" part but yes, getting the one you need is a hell of a lot less hassle.
Old 09-19-2019, 10:35 AM
I have an OE 442 wheel on the wall in the garage doing it now, it was a sprayed blue wheel I got off eGay, wasn't aware it was sprayed, and it's sweating and sticky. Seen it before, once it does that it's toast.
You can search here, it's actually more common than one may think.
Old 09-19-2019, 10:58 AM
I have seen sticky, gooey wheels but those were never painted. The one in my Formula Astre (yeah, they made them) turned so gooey, if you touched it, it would be stringy. Yuck!
Old 09-19-2019, 11:54 AM
The original (vinyl) ? wheel in my 69 GTO gets sticky sitting in the hot trailer. Yuck is right.
