Closed Thread
Old 09-14-2019, 08:26 AM
jamaca85 jamaca85 is offline
feel your pain.. had a crank break in half a couple years back...not a good sound to hear. good luck
1970 firebird, 468, e heads,
Old 09-15-2019, 06:23 AM
tailored68......... tailored68......... is offline
How many Ponty engines you got?
Old 09-15-2019, 06:25 AM
If you can AFFORD to be out of your comfort zone then good luck to you..
Old 09-15-2019, 12:33 PM
Bill Eveland's Avatar
I have a 67 400, and a stock complete 70 455. So have those to choose from. Also just picked up a 57 Pontiac rear with 4.10 posi that has some value to help fund this. . If i could would want an aftermarket block.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 09-17-2019, 01:58 AM
Dragncar Dragncar is online now
If that 67 400 is a 2 bolt, non drilled put some splayed billet caps on it. They are the best 400 block short of a RAV. Real thick bores. you can take them .090 + (with sonic check)
Old 09-17-2019, 05:08 AM
SO are you telling me that a 68 400 block is not as good? Why? But the 68 heads are better, right?
Old 09-17-2019, 06:27 AM
With either of those blocks I would say that you should install Steel main caps on them if you can afford that whole process.
If not then I would build the 400 due to its lesser main Bearing speed and meatier main caps even if there only 2 bolt.
If you take the hour and a half worth of time to polish over all the sharp edges on the factory 1 thru 4 main caps but for each caps Bearing parting line it will be a lot harder to just out and out crack them.
Old 09-17-2019, 04:13 PM
The 67 400 is a 2 bolt and was looking into splayed caps. It needs a sleeve or could just overbore it some. After a sonic test to see how thick it is. A stock wristpin got loose and wore a small groove into the bore.
Im thinking the 455 was like mine and drilled for a 4 bolt but only has 2 bolt caps. Could also put straight caps on the center 3 if so.
How big of a difference between splayed and straight for strength? I was going to put in the longer locating dowels as well.
6.27@107
9.97@131
Old 09-17-2019, 05:35 PM
shaker455's Avatar
Splayed is way to go Bill.
The caps reach right out to the pan rail.
I did a set on a 400 2-bolt block.
Servicing the Pontiac community over 20 years
Old 09-17-2019, 09:11 PM
The 67 400 was the first year of the "new" 400. 66 389s had LOTS of problems over heating and cracking bores due to thin bores. So PMD made the 67 with extra thick cylinders because they did not want bad press and come backs. It was just a nice beefy block.
Dan Whittmore told me all this and he was in with the GM engineers.
BTW, I grew up with a 66 Catalina station wagon. It finally died due to cracking a bore.
It was the block Marty P chose to put twin turbos on and make 1400 HP back in the day.
I have one and it is .060 with pits in 2 holes. I will take it .090-.100.
Old 09-19-2019, 12:06 AM
3fastgtos 3fastgtos is online now
Originally Posted by Elarson View Post
If you feel that it's oil starvation (which creates intense heat, lots of friction and rips the rod apart), then I'd seriously consider going away from the 20w-50 oil. A thinner oil will get more flow to the bearings (less dumped over the pump relief valve) and the bearings will run cooler. We ran 10w-30 in the Grocery Getter and never had a bearing failure.
FWIW:
Eric
Eric,
Do you remember your main and rod bearing clearances?
SD
Old 10-09-2019, 08:10 PM
Looks like crap, lol. Main caps were walking. The main cap that broke with the bent bolt bent the dowel pin some too. I visibly dont see any cracks , but a git was taken at the outer main cap bolt . Maybe fill that in with another allen head bolt and loctite it in?i did hone cyl 4 a little bit. Rod 4 was the only one that spun. So it wasnt.a feed issue, cyl 1 looked good.
ID:	521883   Click image for larger version
ID:	521884   Click image for larger version
ID:	521885   Click image for larger version
ID:	521886   Click image for larger version
6.27@107
9.97@131
Old 10-09-2019, 08:56 PM
AIR RAM AIR RAM is offline
Wow, you may be able save it and just have block checked for cracks and if its good I would:
Replace ALL the dowels.
Since its already drilled for 4-bolt mains, get the non splayed 4bolt main caps (Program Eng)
Bore to next size that cleans it up
rebuild with lighter weight rotating assembly that will live & 7,000 RPMS!
Then install a two stage rev limiter for burn outs and red line!
You may want to check the classifieds, George is selling a set of 6.7" aluminum rods for a song and a prayer... I would have picked them up if he was selling them 2 months ago.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 10-21-2019, 05:22 PM
Update, so the block is not cracked. I have some extra main caps in can see how centered they are, plus a new main stud. I was also going to use the longer dowel pins that Precision automotive sells to help with the cap walk
. Than can get a forged crank, rods and 5 of my pistons are usuable. There is still some visable damage closer to the bottom of the cylinders and can take out the high spots getting it honed out
http://www.precisionautomotivespecia...ine-Parts.html
Or just do the 400 block and splayed caps for quite a bit more money and build from scratch.
6.27@107
9.97@131
Old 10-21-2019, 06:32 PM
Bill, unless you have severe set of main caps to trial fit, you would be better off with aftermarket caps. They are undersized to allow for select fitting to the main saddles. Have the machine shop align bore the mains to within .003-.005 and align hone to finish size.
Dr. Thomas Sowell
Old 10-21-2019, 08:04 PM
I have 2 from a 428 block. I have to remove the bent dowel on #2 and see how it fits, centered wise. I realize only 2 and 3 will work. If these do t.work, may go ahead with the 400. I see people selling stock 4 bolt caps on here and never hear about issues getting them to fit?
6.27@107
9.97@131
Old 10-21-2019, 10:57 PM
People sell caps all the time, but they don't have to make them fit, either. Pontiac caps are difficult to fit because of the way they are retained. Blocks that use register press to retain the main caps are easier to fit, since you can weld the side of the main caps to adjust their fitment to the main saddle. With Pontiac caps, you normally have to radically cut them (as in .030-.040 or more) to get them to align with the main saddle. I've align bored around 6,000 blocks. I've replaced the caps and align bored 1,500+blocks. It's never as easy as you're assuming it is. I'm just attempting to save you headaches and wallet aches....
Dr. Thomas Sowell
  #38
Old 10-21-2019, 11:05 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Go steel main caps
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
  #39
Old 10-22-2019, 11:01 AM
Thanks for the info. ill drop the caps off today and if they don't work will decide from there.
6.27@107
9.97@131
  #40
Old 10-22-2019, 11:36 AM
Good plan
Dr. Thomas Sowell
Closed Thread
