Old 08-03-2023, 05:26 AM
64speed's Avatar
64speed 64speed is offline
Default Trunk sides
When AMD replaced my quarter panels the new quarters have no protection on the inside meaning if something was to slide the side it could potentially dent the quarter from the inside. Is there anything I can do to protect the inside of the quarter?
Old 08-03-2023, 08:56 AM
Rich-Tripower's Avatar
Don't carry heavy, hard stuff in the trunk that isn't at least strapped down? Or you could make some heavy upholstered side panels to install inside the trunk.
Old 08-03-2023, 06:32 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Had a Buddy that was a finishing carpenter make a trunk liner kit for my 64, it's all 5/8 cabinet grade plywood
all friction fit and then covered with neoprene. Mind you I don't carry a spare. 1st 2nd and after pics. last is Black not grey as shows in picture.
ID:	617352   Click image for larger version
ID:	617353   Click image for larger version
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 08-06-2023, 01:46 PM
Dick Boneske's Avatar
When my '64 GTO was new, the first time I took it to the drag strip, I put my SK toolbox in the trunk, along with the drag slicks. The tool box hit the inside of the driver's side wuatrer panel the forst right turn I made. Sure enough, there were two dimples from the corner of may tool box plainly visible from outside the car.
That was my first lession in putting something in place to prevent more dents.
Name:	'64 GTO Lettered.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
