Old 06-04-2020, 07:19 PM
racerboy's Avatar
racerboy racerboy is offline
Default Power steering whine
Over the winter, I converted my manual steering to power steering to my ‘70 Judge to make it easier for me to drive (I suffered a brachial plexus injury a decade ago and have limited use of my right arm). The install went relatively smoothly and I had a shop adjust everything and align the car. I’ve only driven the car a couple of times since the conversion and I noticed that the steering box makes a ‘whine’ when you move the wheel, even when sitting still. In addition, the fluid looks awfully low and foamy? Could low fluid alone cause this issue, or could there be something wrong with the rebuilt p/s box.
https://vimeo.com/426063086
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 06-04-2020, 07:26 PM
77 TRASHCAN's Avatar
From my experiences, the noise indicates a pump problem. Go to an auto parts store. Lucas makes a power steer additive/stop leak. That stuff can help!
Shut it off
Shut it off
Old 06-04-2020, 07:27 PM
racerboy's Avatar
Wow. That was fast. The pump is brand new. Or at least, reproduced. Pretty sure it came from our sponsor here.
Old 06-04-2020, 07:29 PM
racerboy's Avatar
Video of noise (hopefully this posts right)
Old 06-04-2020, 08:30 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
Ugh, that does sound bad.
When you say the fluid looks low, you mean like not registering on the dipstick low? Foamy usually indicates air in the system.
Here is how I do mine.
Make sure the proper fluid level is met.
Remove cap
Start up engine
Turn wheel while running - hold at stop and rev to 2500. (careful, the cap is off) This this on one side then to the other.
Do this 3x
Center when done
Shut off engine
Recheck fluid.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 06-04-2020, 08:48 PM
OG68 OG68 is offline
From the Jim Shea Steering Papers.
http://jimshea.corvettefaq.com/?p=593
No need to run the engine to get the air out. The steering gear acts as a pump when you rotate the wheel back and forth expelling the air.
I have done it this way several times and it works..
2007 Cadillac SRX
Old 06-04-2020, 09:47 PM
PontiacJim1959 PontiacJim1959 is offline
And with limited use of your arm, you may want to lift the front tires off the ground to make it easy to turn, lock to lock a couple times.
Make sure you have the correct PS fluid.
Old 06-04-2020, 10:05 PM
racerboy's Avatar
Thanks for the feedback. I’ll definitely make sir that the proper amount of fluid is in there and will rotate the wheel lock to lock, as described.
Old 06-05-2020, 12:48 AM
Thanks Jim, forgot that small detail. I use Delco power steering fluid in my ElCo.
2007 Cadillac SRX
Old 06-05-2020, 06:50 AM
60's-Early 70s GM Power Steering seems so darn Low-Maintenance. Doesn't it.
Old 06-05-2020, 12:07 PM
Once the system is dialed in its pretty much maintenance free. But sometimes getting it dialed in correctly can be frustrating. I learned a lot from the Steering Papers.
2007 Cadillac SRX
Old 06-05-2020, 06:14 PM
I found a youpulit PS Pressure hose that wrapped UNDER the PS Box, then went to Back of Pump. Currently using that, no weeps, no leads, no high loops.
Hose features a 3/8 steel tubing to do the wrapunder, then exits with rubber flex. Will sport a photo sometime.
