Old 01-28-2014, 02:04 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Default .842 lifters
Ok I did a search earlier and instead of bringing up old stuff I thought I'd start a new thread.
First off thoughts on the Crower endra lifters with the needless roller?That's what I'm gona run in the new motor and that's what Jim Butler talked me into due to current availability.compared to the RedZone's
2. I've read in past post guys are saying 1000psi max on those .842 lifters and is that over the nose psi or over the nose psi times rocker ratio?
3. I've also read about Gaydosh's 1100hp beast and he used the .842 lifter on that monster how did the lifters hold up and for how many passes.........now I know there is no one in heck my new motor will even come close to that # but I'm curious because I might attempt to run similar pressures on that little roller wheel.
Anyone have any good experience with these things and running a run count up into the 300-400 run mark at close to 900 over the nose with a 1.85+ rocker ratio?
Thanks guys
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.904@161.50 in St.Louis Oct 4 2024
Old 01-28-2014, 08:13 AM
mike leech's Avatar
mike leech mike leech is offline
They are good.
For what you are doing I like the .904 stuff better. I'm only .825 lift and went .904.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
The Following User Says Thank You to mike leech For This Useful Post:
Old 01-28-2014, 09:34 AM
S/st 54's Avatar
Originally Posted by mike leech View Post
They are good.
Thanks for the input......Now I'm curious if I went to the .904 lifter and knowing the wheel or roller is bigger how much does that increase my duration of my current camshaft?
Old 01-28-2014, 09:47 AM
Tom McQueen Tom McQueen is offline
Obviously all numbers are approx.
An increase to an .810" roller wheel from the standard .750" wheel will increase duration .8 degrees at .020" lift, 1.3 degrees at .050" lift and 1.7 degrees at .200" lift.
An .850" roller wheel almost doubles those numbers and a full 1.00" roller wheel really pops that valve open.
The Following User Says Thank You to Tom McQueen For This Useful Post:
Old 01-28-2014, 09:27 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
We are running the .842 lifter...still. I would have liked to go the .904, 55mm cam. Hopefully next rebuild.
We are running the ISKY EZRoll Max. 1000 lbs PAC springs.
Hope to be on the dyno next month. Hoping for 2hp/cube. We'll see.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
The Following User Says Thank You to grnmnstr For This Useful Post:
Old 01-28-2014, 09:40 PM
hp 400 dave's Avatar
hp 400 dave hp 400 dave is offline
Did you find a dyno to use Tom?
Old 01-28-2014, 10:44 PM
Think so. Waiting for the CV-1's to comeback from Jesel and we can assemble it all.
Old 01-28-2014, 11:15 PM
Pitch 400 Pitch 400 is offline
Any thoughts about Slowbird's deal with the Crower bushed lifters? I'd like to get away from the needle bearings too since I don't drive my car that much.
Old 01-29-2014, 01:34 AM
S/st 54's Avatar
Thanks!
What rocker ratio are you running and are you running over .850 on lift?
I hope you hit that 2hp per ci that would be sweet!
If mine hits 1.8 per I'd be doing back flips!But in all reality I'm just trying to assemble a 535 using nice parts,and want it to to live for 200-250 passes( before I roll a new set of plugs in it,new springs,new rings and bearings). When I take it to the dyno it's to get the fuel right and find a happy place with timing and LOL maybe find the"Denver Tune up"
Old 01-29-2014, 01:39 AM
mike leech's Avatar
Thanks!
thats my engine.....but 1.87
EHTTFMF!
Old 01-29-2014, 08:02 PM
S/st 54's Avatar
Uh oh dare I ask what do you mean that's your engine?
Old 01-29-2014, 08:10 PM
mike leech's Avatar
bunch passes. 1.87 hp per cube. whole season on the same set springs......same spark plugs all year.
EHTTFMF!
Old 01-29-2014, 08:55 PM
S/st 54's Avatar
Ok ya had me worried for a sec. LOL
Old 01-29-2014, 09:33 PM
lemans411's Avatar
lemans411 lemans411 is offline
i went .904 on new engine i think its worth the upgrade.
i'm not that interested in "pushing my luck" after the 535 crapped its pants all over b.i.r. just my $ .02
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
Old 01-29-2014, 10:02 PM
S/st 54's Avatar
LOL your killin me! Sounds like you need to get ahold of Dennis @ DRE.I wish I would've gone with the .904's also but I already have the nice .842's and I just got told by My wife,that she wants her living room floor back so it sounds like I need to chit or get off the pot on this new motor and start assembling it.......now I just need to order some rockers and a oil pan and probably some pushrods.
Old 01-29-2014, 11:36 PM
lemans411's Avatar
engine diapers? yea im hoping i wont need that lol. im sure they will be required in more classes eventually
-Rob
68 gto
Old 01-30-2014, 12:57 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Here is the first set of Hill Performance, 100% USA made Pontiac solid roller lifters.
These lifters come standard with high pressure pin oiling, available with bronze bushings, sizes from .842" to .937".
Custom offsets available.
This lifter has been designed to exacting tolerances, 100% USA made materials and high quality finished.
The first sets will be tested over the next few months with live orders available by June.
Calvin Hill
Hill Performance
708-250-7420
ID:	351273   Click image for larger version
ID:	351274   Click image for larger version
The Following 4 Users Say Thank You to 65nss4spdGTO For This Useful Post:
Old 01-30-2014, 01:02 AM
lemans411's Avatar
Calvin Hill
Hill Performance
708-250-7420
needles or no?
-Rob
68 gto
Old 01-30-2014, 01:33 PM
grnmnstr's Avatar
Thanks!
I am running 1.9 on both. Cam is somewhere around .850" lift, I know it isn't over .900". The Tigers still have some left in it. These only flow 444 cfm. I too, am just looking for reliability and consistency. This is a T/S bracket motor.
Old 01-30-2014, 01:47 PM
grnmnstr's Avatar
This motor will be a 535 as compared to the 527 in my sig. The 527 was never dyno'd, but I figure it was about 1020 HP, based on the weight and mph.
We found a few "issues" with the 527, so we probably had left some HP on the table. We added the right cam and a few other goodies to the new 535, so we will be close to the 2 HP/cube. I know it is a high expectation given the head flow, so we will see how close we get.
