Old 09-12-2021, 04:11 PM
Mike S's Avatar
Mike S Mike S is offline
Default Need to soften 60' times?
Hi guys, Is there a good way to soften (slow) 60' times. I am running 10.0 index and the car is 60'ing real good with the new radials. It is pulling 1.35 60's. Yesterday just pulled a 1.34 60' in 3rd round which made me run under with a 9.97.
I am running a restrictor plate with 1.65 holes and have 200lb of ballast. I am also pulling 4 deg of timing in high gear, Car runs 10.00/132 with a 1.35 60'.
I am running a th400 with an 8" converter. I launch with a trans brake at 3800. I need to keep the brake to hit the pro tree. I am running all stock a body suspension.
I have the slowest mph and best 60' in my class. So it is a little disadvantage getting chased. Getting tired of looking behind me.
Old 09-12-2021, 04:23 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Have you tried dropping launch rpm , maybe to 3600?
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 09-12-2021, 04:27 PM
I would think a higher 1st gear would work good?
Especially if the top end RPM is where you want it.
Is the 1st gear still a 2.48 gear?
A 2.10 may soften the launch enough.
Or launch in 2nd gear.
Old 09-12-2021, 04:28 PM
Mike S's Avatar
I have but then my reaction time slows.
I have tried foot braking but can't cut a light. Foot braking at 2000 60' is 1.40.
Old 09-12-2021, 04:33 PM
Mike S's Avatar
Yes 2.48 first gear with a 4.10 rear gear. I am flirting with changing the rear gear. Not many choices in pro gears for a 12 bolt unless I go back to street gears.
Right now my shift light (6400) comes on 50' before the stripe. I cross at 6800.
Old 09-12-2021, 04:57 PM
Changing the rear gear to a higher gear may soften the whole run?
Old 09-12-2021, 06:33 PM
Scott65's Avatar
Scott65 Scott65 is offline
Pull timing at launch, if thats an option. You may be able to get the reaction times you need with lower launch rpm if you can really finely tune the front suspension.
Old 09-12-2021, 07:21 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
JMO, but in Pro Tree racing, I would want 60' to be great, so the lights are good.
I would concentrate on other things. Pulling timing at top end, shifting sooner, etc.
I understand your point about being chased, but they should be next you most of the way. Easy to tap the brakes.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
The Following User Says Thank You to grnmnstr For This Useful Post:
Old 09-12-2021, 09:49 PM
aaronman aaronman is offline
When index racing I typically set-up .05 fast and then spot drop to my number. It's better to be fast than slow. If you run a GRID you can pull timing with a couple key strokes without hurting the rest of your set-up.
Old 09-13-2021, 02:11 PM
Lee's Avatar
Lee Lee is offline
Holley carb? If so, go with smaller squirters.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 09-13-2021, 02:53 PM
beemergary's Avatar
Run a 11:50 index foot brake nostalgia super stock class. Car 99 % runs too fast. Use my shifty light and extra mini shift light near finish line. Won more $$ and no. 1 qualifier this year than probably past 8yrs.
Old 09-14-2021, 05:38 AM
Dragncar Dragncar is offline
I run one of the MSD dials instead of a chip.
I usually launch at 3600 RPM but it sure slows down if you turn it to 2200 RPM.
Its easy, reach down and turn the dial, play with it and find out what works.
Old 09-14-2021, 08:09 AM
Mike Davis's Avatar
I run a 3.90 gear and my car is set up for a 10.00 index. 60ft the way its set up is 1.37 and the MPH at the stripe is 134 which gives a decent top end charge. Going from a 4.10 to a 3.90 the ET didn't change much but the 60 went from 1.35 to a 1.37 and the MPH from 132 to 134.
My car is 3750lbs with stock suspension.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 09-14-2021, 12:59 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Cool
Originally Posted by beemergary View Post
Car 99 % runs too fast. Use extra mini shift light near finish line.
This doesn't smell right, what exactly is the second light for?
Dave Polichena
Old 09-14-2021, 03:37 PM
Formulas Formulas is offline
A second light could advise a driver of potential breakout, RPM is wheel speed which is MPH when that light comes on back off or tap brakes
My guess anyways
Old 09-14-2021, 08:12 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Glide?
Old 09-14-2021, 10:41 PM
beemergary's Avatar
My guess anyways
Good answer for me. This event happens allittle before finish line. I base it by the weather also and don't add weight or adjustable throttle plates.
Old 09-15-2021, 05:58 AM
Higher RPM at the stripe does not necessarily mean better E.T.more MPH.
Old 09-16-2021, 01:32 PM
mysticmissle's Avatar
stripe driving is tough but if your consistently 03 to the good i would prefer that to cutting an 00x light and not being able to get to the stripe and having an mediocre light get past you, if you spin ever so slightly
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 09-16-2021, 09:26 PM
Mike S's Avatar
There is starting to be a lot more new vet's and camaro's running High mph close to 140. Seems most cars are 134-135. Everyone I run is faster.
Main problem I am having is when I am in the right lane. Having a tuff time picking them up if they are behind me, ever since I installed the window net.
I love the way the car launches. Have it set to cut .00 to .01 lights if I remember to concentrate.
I am going to add a door mirror and adjust it for the other lane be for I do anything to change the car.
Kicking myself for losing 3rd round. Had him beat on the tree his .090 light to my .015. Couldn't find him and hit the brakes to late (9.97). The 1.34 60' got me by surprise. Actually it was embarrassing I would have rather red lighted.
Thread Tools
Display Modes
