73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 09-21-2020, 11:45 AM
MarkS57's Avatar
MarkS57 MarkS57 is offline
Default 76 versus 73/74
All, I know there is a difference in the motor mounts used in a 76 versus a 73 / 74 but I am wondering if the 76 frame still has the holes for the 64-74 frame brackets or at least can they be drilled?
Thanks!
Mark
65 Tempest, 400, TH400
86 Fiero SE 2.8
Old 09-21-2020, 01:21 PM
Grand73Am Grand73Am is offline
I think the holes are there. I have a 73(with old style mounts) and a 75(with clamshells). As best I can see on the 75, considering the engine is in the car, I see holes in that area where 73-74 pedestals would be.
My question would be why you would want to replace the superior clamshell motor mounts with the inferior older style?
Steve F.
Old 09-21-2020, 01:33 PM
MarkS57's Avatar
Thanks for the reply & good question. I want to put my 428 into this car and it only has the 2 hole block mounts which will work with the older mounts. I know there adapters out there but unless there are different ones than Ames has, it sounds like there is an interference problem with those Ames adapters; stated as such by Ames themselves.
86 Fiero SE 2.8
Old 09-21-2020, 01:41 PM
You might check with Butler Performance for adapters. You could call them to see if they can tell you if there are any problems with the way their adapters fit: https://butlerperformance.com/c-1393...-adaptors.html
Steve F.
