Aluminum tri power intake?
Did pontiac ever offer the manifold in aluminum, or is that an aftermarket deal only?
Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
yes,a 1961 SD tripower that fit the 306 SD heads.There has been a couple engineering 63 in alu I believe.Tom
3x2 aluminum intake
I'm assuming you meant to ask if they offered a 3x2 aluminum intake for a 66?
No. No, they did not. There are some aftermarket ones floating around, but not ones from the factory. |
Aftermarket 66 was made a few years back. I’m running one on my car. Very well made complete with build date
The Following User Says Thank You to DiamondJim For This Useful Post: | ||
Jim, how fast have you been with the tri power? Building a new street engine and have not decided between 2x4, Or 3x2......
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
There are a couple of versions of the 66 tripower intakes.
Version 1, about 200-300 made in the USA under the guidance of Steve Scheitinger. Perfect fit and finish. Maybe a slight change to a casting number to avoid the wrath of GM. I bought 2 of them from him directly. Version 2. Parts Place- Made in Taiwan. I've heard bad comments, but never used one or looked at it closely. |
AL TriPowers
Be advised that there is an absolutely huge difference in the quality/appearance of the first run domestic vs the later offshore imported aluminum TriPower intakes, as Andre posted.
I sent my beautiful first run USA made intake to Dave Wilcox for some extensive porting many years ago, and there was a mix up- he actually sent me back a Taiwan made piece of crap. When I opened the box I was shocked. He swore up & down that was definitely the intake I sent him- and the only way I was able to finally prove that it was not was that the pics I had taken prior to shipping it to him. The casting dates are different between the two versions. He was forced to own up to the mistake, and he was able to get my intake back from the guy he sent it to. That guy must've been overjoyed when he first opened his box- and really bummed when he had to send it back and get his original piece of crap intake back. The first intake Dave sent back was ugly as hell- a disgusting mottled coloring and a very, very rough casting finish. Dave had only done minimal port work, and not separated the crossover to it. Closest I've ever had to having a heart attack when I opened that box up...
1966 GTO (Red) WARPATH 455CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 464CI TriPower 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed Last edited by 3X24SPD; 09-29-2020 at 05:51 AM. |
The Following User Says Thank You to 3X24SPD For This Useful Post: | ||
Good info. I will tale a closer look when my friends intake is back from the machine shop. Here are a couple of photos I took to keep track of linkage... can't really see the intake very well, but how does it compare to yours?
Thread Tools | |
Display Modes | |
