LPETE - The wife doesn't remember where the got it, but I think Cen-Tech is a HF house brand.
cm
If the rules don't say something is illegal, I have to assume it is legal -- Smokey Yunick |
Venturing a guess...I think you use the dial to set the bepp/diode function and then use the button to select which function, i.e. beep or diode. the display should change to indicate the selection.
The manual should give you hte specifics. I also believe that is the brand from Harbor Freight. George
George -
I think you're right about the beep thing. It's really a short, p*ss-poor manual for those of us who don't do this on a daily basis. I'm also guessing that micro & milli-amps measurements are for either AC or DC, since the DC symbol is over the AC symbol. I'll also go back to the manual to see how to measure Hz; seems to me that has to do with sound? Don't know what I would be measuring. In any event, I'm going to keep this thread. Thanx, again, for all the input. cm
I just can't stop asking questions. What is the mACX red plug for?
cm
yep, Cx is for measuring capacitance.
Hz is Hertz, a modern name for "cycles per second". You can measure the frequency of an AC signal, whether it's your AC wall outlet (should be 60 Hz) You can even use this function to measure the frequency of the ignition pulses and calculate the actual RPM of the engine. George
George -
Thanx for all you info. Yep, I think you could/should write your paper on this. Do you know of any good references? With every answer you give, I think up more questions. I'll stop now, and let you get back to your day job. cm
I am not sure if it was mentioned earlier, but you need to be very careful when measuring current through these meters. They can only handle a very limited amount of current, as the current is being drawn through the meter. I purchased some very high CFM ford electric fans, and I wanted to measure current. I recently added a Fluke i1010 to my arsenal which allows me to measure 1000A DC current, when attached to my 87V. The fans I measured run on high at about 35A, which would have killed my 87V. These fans on initial startup pulled over 85A! My next step is to see what kind of current draw I am getting from my IMI starter. I suspect my ground circuit is not up to snuff, which will limit the current, or cause a significant voltage drop? Anyways, I just wanted to post that you do need to be careful how much current you send through your DIMM. Cheers.
How many of you have driven over 340? |
Lots of excellent electrical help around here especially professionals like George and at least two other folks whos names I dont recall. They are obviously well qualified like George is.
On the meters, It seems the pro meter is a Fluke brand. Those are several hundred dollar professional instruments. Beyond reason for most hobbiests. I have a $10.00 Harbor Fright multimeter that has all the functions and functionality of the other multi I own which is a $50.00 SunPro which as far as I can see does all a Fluke will do? A $10.00 meter and a $6 light probe will give you all the diagnostic power the average Pontiac fixer will ever need. That and the excellent step by step procedures George often offers. Point is, you don't always need pro level ($$$) tools for these auto electrical deals so don't feel that the cost of a multimeter can hold you up. A little reading wont hurt either, I have a fair layman's knowledge of electrical theory but since I dont do every day like George, I often refer back to a text to help comprehend the results of a test I have done. (Like how can I get the smoke back in the wire?) Off my MEDS again & LOVING IT! |
A new wire already has the smoke installed.
True that Fluke is probably the high end of the hand-held meters, but Sears often has good meter values on sale too. The fuses Fluke uses, BTW, are that expensive, because they are rated to be able to interrupt (blow) a large fault current. The typical 2AG glass aren't rated for that. Assume you have the meter set to current and decide to use the meter on the AC lines coming into your house. In current mode, the meter is essentially a wire and doing that will create a short circuit across the AC mains, which will blow the fuse. However, the AC mains can source many thousands of Amps instantaneously. The fuse has to be able to interrupt that nasty of a fault. Moral of the story....check your settings and the jack positions when you are using your meter. George
I just picked up a mulit-meter....it is an Electronic Specialties model and from what I can tell it is a pretty nice unit with all the functions that I will ever need. However, the user's manual is a "pile of crap"! Not detailed at all and very poorly written. I found at least 6 misspelled words in it with just a quick read-over.
Is there an on-line user's guide to multi-meters that could be downloaded or printed out? That would be a great help! George's posts are great, but to have this in one handy booklet or print-out would be fantastic rather than asking message board questions everytime something comes up. Thanks!
1966 Bonneville Convertible, 421, 4spd. (in progress) 1966 Bonneville 4 Dr. Hdtp. (survivor) 1999 Trans Am Hatchback, red, 6 spd. |
My sons and I call this the "book test". When we buy stuff, if the book is thin, we say it doesn't pass the book test.
George
My trusty sidekick.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
I'm with wfbarto -- that's the kind of real world stuff we need.
cm
#38
Let's see what George has to say.
#39
General use of multimeters and diagnostic techniques can be a large topic.
Debugging specific automotive cases may be easier to handle. I'll think about it but in the meantime if there are specific topics anyone wants addressed, post them and we can answer them quickly. George
#40
