Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 09-03-2020, 07:46 AM
scott70's Avatar
scott70 scott70 is offline
Default Formula wheel horn contact pin kit
So I got the whole kit to convert my 70 GTO from the standard steering wheel to a formula. It came with a horn contact pin kit which is pin,spring and a plastic retainer. The retainer sent is a twist lock type. I took my wheel apart and my retainer is a push in friction type with a rib in the middle. There are horn pin kits available with the type of retainer my car has. Maybe the kit from Ames should have both types of retainers? OER makes a kit # 748741 for a visual.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-03-2020, 03:57 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
This is the only one still available from GM. If you shave down the little pin , the assembly should press in snugly and operate properly.
Smilies are Off
